An client of mine is having speed issues on his lan and has ask me if I can find a solution.
I have read that mikrotik are able to do ethernet bonding to increase speeds.
In another post I have read that if you do a speedtest using mikrotik bandwidth server then it does not go higher that 100mb/s per Ethernet. So if I want to test gigabit speeds I must test though router not from router?
But does the connection support speeds up to 2gigabit?
