What’s giving me enabling VLAN Bridge Filtering in bridge? VLANs still works without it
If it works what is your issue??
If you are looking for info..
https://wiki.mikrotik.com/wiki/Manual:Bridge_VLAN_Table
https://help.mikrotik.com/docs/display/ROS/Bridge+VLAN+Table
https://www.amazon.ca/Routeros-Example-2nd-Stephen-Discher/dp/0692777903
https://www.amazon.ca/Theory-laboratories-exercises-Mikrotik-RouterOS-ebook/dp/B07X5MHR1Y/ref=sr_1_5?dchild=1&keywords=mikrotik&qid=1618314376&s=books&sr=1-5
and hot off the press
https://www.amazon.ca/MikroTik-Switching-LABS-Certification-covered/dp/B08ZW38C46/ref=tmm_pap_swatch_0?_encoding=UTF8&qid=&sr=
I don’t fully understand this:
Bridge VLAN Filtering since RouterOS v6.41 provides VLAN aware Layer2 forwarding and VLAN tag modifications within the bridge. This set of features makes bridge operation more like a traditional Ethernet switch and allows to overcome Spanning Tree compatibility issues compared to the configuration when VLAN interfaces are bridged.
What means that(?):
How it exacly works without enabling VLAN Filtering in bridge?
When VLAN filtering is not enabled on the bridge it behaves like an unmanaged switch - packets with any ethertype, including 802.1Q VLANs, are forwarded to all* ports.
(* - based on the usual learnt MAC address forwarding table)
