What's using the memory?
I have a hAPax3 acting solely as an AP (connected to an RB5009).
Everything is working well – no complaints.
The wifi connection to the computer I’m posting this from (Beelink mini PC) is connected using 802.11ax at rx/tx of 576/681 Mbps.
Nonetheless, I’m wondering if I can get a slightly zippier experience.
I see the hAP is using about 400MB of RAM and I’m wondering if anyone know how to figure out what exactly is using the memory:
[admin@212hAP-Ax3] /system/resource> print
                   uptime: 1w5d7h54m27s
                  version: 7.17.2 (stable)
               build-time: 2025-02-06 09:10:24
         factory-software: 7.4.1
              free-memory: 637.0MiB
             total-memory: 1024.0MiB
                      cpu: ARM64
                cpu-count: 4
            cpu-frequency: 864MHz
                 cpu-load: 2%
           free-hdd-space: 92.7MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 1417732
         write-sect-total: 65341359
               bad-blocks: 0.2%
        architecture-name: arm64
               board-name: hAP ax^3
                 platform: MikroTik
Wifi connections are:
[admin@212hAP-Ax3] /interface/wifi/registration-table> print
Flags: A - AUTHORIZED
Columns: INTERFACE, SSID, MAC-ADDRESS, UPTIME, LAST-ACTIVITY, SIGNAL, AUTH-TYPE, BAND
#   INTERFACE  SSID                MAC-ADDRESS        UPTIME       LAST-ACTIVITY  SIGNAL  AUTH-TYPE    BAND
;;; 49TCLRokuTV - Thomas
0 A wifi1      Upstairs5g-0F0493   0C:62:xxxxx  2d22h53m47s  9s             -49     wpa2-psk     5ghz-ac
;;; Screek Human Sensor 2A 16 LR
1 A 2point4    2point4             EC:DA:xxxxx  8h6m39s      0ms            -58     wpa2-psk     2ghz-g
;;; Beelink 212 DR
2 A wifi1      Upstairs5g-0Fxxxx   70:D8:xxxxx  2h24m50s     0ms            -60     wpa2-psk     5ghz-ax
;;; Susan iPhone
3 A wifi1      Upstairs5g-0Fxxxx   60:57:xxxxx  45m27s       0ms            -51     ft-wpa2-psk  5ghz-ax
;;; JRS Iphone
4 A wifi1      Upstairs5g-0Fxxxx   7C:4B:xxxxx  45m15s       3s             -68     ft-wpa2-psk  5ghz-ax
5 A wifi2      Upstairs-2G-0xxxx  10:6Fxxxxx  3m13s        3m9s70ms       -71     wpa2-psk     2ghz-g
ether1 (WAN) connection looks like this:
And, of course, here is the config. I seem to have lots of firewall rules, but I think I don’t need any given that this is just an AP, correct?
I also question whether I need to allow remote requests for /ip DNS given that the RB5009 is the DHCP server and the DNS provided to DHCP clients is that of the RB5009 (upstream)?
# 2025-03-29 15:33:26 by RouterOS 7.17.2
# software id = 5NRD-V1QF
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDG0
add admin-mac=48:A9:8A:0F:04:8F auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=ether1 ] comment="To RB5009" poe-out=off
set [ find default-name=ether3 ] comment=TV
set [ find default-name=ether4 ] comment=TV
set [ find default-name=ether5 ] comment=OffBridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    disabled .width=20/40/80mhz configuration.antenna-gain=0 .country=Russia \
    .mode=ap .ssid=Upstairs5g-0F0493 .tx-power=24 disabled=no \
    security.authentication-types=wpa2-psk .disable-pmkid=yes .ft=yes \
    .ft-over-ds=yes .management-protection=disabled
set [ find default-name=wifi2 ] channel.band=2ghz-g .skip-dfs-channels=\
    disabled .width=20mhz configuration.country="United States" .mode=ap \
    .ssid=Upstairs-2G-0F0494 disabled=no security.authentication-types=\
    wpa2-psk .disable-pmkid=yes .ft=yes .ft-over-ds=yes \
add configuration.mode=ap .ssid=2point4 disabled=no mac-address=\
    4A:A9:8A:0F:04:93 master-interface=wifi2 mtu=1500 name=2point4 \
add configuration.mode=ap .ssid=blueberries disabled=no mac-address=\
    4A:A9:8A:0F:04:96 master-interface=wifi1 name=blueberries \
    security.authentication-types=wpa2-psk .disable-pmkid=yes \
add comment=defconf name=WAN
add comment=defconf name=LAN
add include=all name=TRUSTED
add comment=offbridge-dhcp-server name=offbridge-dhcp-server ranges=\
    192.168.55.100-192.168.55.200
/queue type
add fq-codel-interval=60ms fq-codel-limit=800 kind=fq-codel name=fq
/system logging action
set 3 remote=192.168.0.13 syslog-severity=emergency
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=2point4 internal-path-cost=10 path-cost=10
add bridge=bridge interface=wifi1
add bridge=bridge interface=blueberries
set udp-timeout=10s
set discover-interface-list=TRUSTED
/ipv6 settings
set max-neighbor-entries=15360
/interface bridge vlan
add bridge=bridge disabled=yes vlan-ids=100
add interface=bridge list=TRUSTED
add interface=ether1 list=TRUSTED
add interface=*6 list=TRUSTED
add interface=wifi2 list=TRUSTED
add comment=OffBridge interface=ether5 list=LAN
/interface ovpn-server server
add mac-address=FE:20:83:39:29:80 name=ovpn-server1
/interface wifi access-list
# Long list removed
add address=192.168.2.5/24 comment=defconf interface=bridge network=\
    192.168.2.0
add address=192.168.55.1/24 comment=OffBridge interface=ether5 network=\
    192.168.55.0
/ip cloud
set ddns-enabled=yes
add address-pool=offbridge-dhcp-server comment=offbridge-dhcp-server \
    interface=ether5 name=offbridge-dhcp-server
add address=192.168.55.0/24 dns-server=1.1.1.1 gateway=192.168.55.1 netmask=\
    24
set allow-remote-requests=yes cache-max-ttl=4w cache-size=32768KiB \
    query-server-timeout=5s servers=1.1.1.1,8.8.8.8,9.9.9.9,8.8.4.4
/ip dns static
add address=192.168.2.5 comment=defconf name=hapax3.212.local type=A
    established,related,untracked
    invalid
add action=accept chain=input comment="allow 67 68 to 10.0.0.1" dst-address=\
    10.0.0.1 dst-port=67,68 log-prefix="allow 67 68  to 10.0.0.1" protocol=\
    udp
add action=drop chain=input comment="drop all to 10.0.0.1" dst-address=\
    10.0.0.1 in-interface=!lo log=yes log-prefix="drop all to 10.0.0.1"
add action=drop chain=forward comment="drop all 10.0.0.0/24 to not-WAN" \
    disabled=yes log=yes log-prefix=drop-all-10-0-0-0-24-to-not-WAN \
    out-interface-list=!WAN src-address=10.0.0.0/24
add action=drop chain=forward comment="drop guest to 192.168.0.0/16" \
    dst-address=192.168.0.0/16 dst-port=!53,68,68 log=yes log-prefix=\
    drop-guest-to-192-168-0-0-16 protocol=udp src-address-list="Guest WiFi"
add action=accept chain=forward
add action=accept chain=input disabled=yes
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
add action=accept chain=forward disabled=yes in-interface-list=LAN log=yes
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes hw-offload=yes
    established,related,untracked disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/ip hotspot profile
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d \
    wed=0s-1d
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set www-ssl disabled=no
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=212hAP-Ax3
/system logging
add disabled=yes topics=wireless
add action=*4 prefix="XXXXXC MikroTik" topics=hotspot
add action=*4 prefix="XXXXXC MikroTik" topics=\
    !debug,!packet,!snmp
add topics=account
add action=remote prefix="192.168.2.5 " topics=info
add disabled=yes topics=dhcp
add action=*6 topics=debug,packet,wireless,dns,netwatch,dhcp
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.2.2
add address=3.pool.ntp.org
add address=0.north-america.pool.ntp.org
/tool graphing interface
add interface=wifi2
add
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=*6
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool netwatch
add disabled=no down-script=Netwatch host=1.1.1.1 http-codes="" interval=1m \
    name=Netwatch-1.1.1.1 test-script="" type=simple up-script=Netwatch
/tool romon
set enabled=yes
/tool sniffer
set file-limit=10000KiB filter-interface=ether3,ether4 memory-limit=1000KiB
/user group
add name=HA policy="reboot,read,write,policy,test,api,!local,!telnet,!ssh,!ftp\
    ,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api"
I have an ax3
Total memory 1024 MiB
Avail Free memory: 651.2 MiB
Meaning used memory is 373.
I do not use any logging or at least minimize it if all possible.
Do not expect the ax3 to be any zippier, unless your holvoe, the rest of us mere mortals get around what you are getting.
I removed the FW rules, disabled /IP DNS ALLOW-REQUESTS, removed the graphing, and removed the logging.
Rebooted and memory used is now 377.
But, my connection speed increased to 720/720 with a -64db signal.
And CPU hovers between 1 and 2%.
Seems like excellent performance to me.
So… You gained 4MB. Why is that bothering you ? ax3 have plenty of memory
wap ax has only 256mb RAM. So the wap ax has already less physical memory as your observed memory usage on ax3.
I’m bothered by a lot of things, just about daily, but not this.
It was nothing more than curiousity, of which I have an overhwelming abundance.
That’s interesting, and piques my curiousity even more.
And begs the question: If a wAPax cam run ROS 7.x in 256MB and still have plenty remaining but the ax3, even with my stripped-down config, uses more than the total amount in a wAP.
Isn’t it possible that different hardware implies different resource usage? Like cars where different models result in different fuel consumption even if their bodies are the same.
Not just possible, but likely.
wAPax: IPQ-5010, ARM, dual core
hAPax3: IPQ-6010, ARM64, quad core
I’m no electrical engineer, but I wouldn’t be surprised if that right there, and the associated required supporting hardware, explains it.
No need to be electrical engineer to check some data: https://mikrotik.com/products/matrix
ROS 32bit vs 64bit?
In x86 world, in typical desktop configuration system running x86-64 consumes around 30% more memory than similarly used i686/x86 system. But this is more or less statistical average, in particular use case (e.g. ROS v7) difference could be larger or smaller. However due to how closed ROS is (no actual visibility of internals) it’s hard to assess if two devices are even “similarly used” and hence hard to compare.
