Where is this 169.254 IP coming from?
I have enabled PIM between two vlans that both have their IP address.
Now log show:
RX IGMP_V2_MEMBERSHIP_REPORT from 169.254.134.72 to 239.255.255.250 on vif vlan100-management: source must be directly connected
Where could this link-local address be coming from?
It is Microsoft!!!
Just google for it :slight_smile:
RFC 3927
Automatic Private Internet Protocol Addressing (APIPA)
or simply 169.254.0.0/16
I know what these kind of addresses are. I am just wondering what device/interface is using it.
Cause Mikrotik can’t ping it.
I don’t have a single machine running Windows in my LAN.
Thank you
Of course you can’t ping it because your router most likely doesn’t have an address in that space on the client-facing interface :wink:
APIPA is not only Microsoft but also Macs and literally any OS uses it. It happens when an interface is configured as DHCP client and doesn’t get a lease.
The Multicast you’re seeing is most likely mDNS.
You should be able to see the the MAC address of that device in your ARP table.
Or create a filter rule with src-address=169.254.0.0/16 and action=log - this will show the mac address in your log. Having the MAC address will help you finding out which machine is misbahiving.
Or - give your router an address in that space and try to connect to this machine to find out which it is.
-Chris
Hello cdiedrich,
Thank you for your message.
Before reading your answer, I tried using packet sniffer to find out the guilty machine but it did not shed a light.
Adding a filter rule as you mentioned it doesn’t help either - counter don’t increment.
Cheers
