Where to buy In Lahore Pakistan ??
I Recently took over a Wifi service which is running the RouterOS 3.20 level 4 with a large customer base and around 3-4km area. I like the OS and wanted to buy another copy for expansion. I was considering either buying a router board or a router or the routeros a new version latest would be best but i cant seem to find the anyone selling anything. Only pirated copies are available here everywhere But I prefer to pay for the license and get a proper device with atleast level 4. Any help would be appreciated. I already tried calling the dealers listed on the mikrotiks website with no luck. I can buy online with a credit card if someone can tell me where i can buy at best prices and how much a routeros level 4 costs
Sincerest Regards
yes you can buy from Karachi and Islamabad, if you need any other help i can assist you
03224498077
LAHORE
I Am not a Dealer of Mikrotik, only i can give you right direction for where you can buy or witch RouterBoard model are good for your setup specially for CABLE-Net Setup and small WISP as your local environment, or if you need any other help for configure your Mikrotik or if you want some suggestions? i can help you and that all help is free of cost
say Thanks to Mikrotik
Salamz THanks for such a generous offer. I dont need help configuring I have been using level 6 router os 4.17 for a few years now I wanted to upgrade to newer versions but I then decided not to. I then wanted to replace my pc running the router os with a rb1100 router board then again decided not. I am a wifi + ethernet small isp in johar town lahore everything is running smoothly. Just wanted to upgrade then decided not to waste the 160 dollars as i couldnt find anything tempting in the newer versions.
SIncerest regards
Naveed Ahmed
03008466858 Hotspot Ultra internet services johat town eblock e1- BOR - Rehman homes wfaqi colony andsurrounding areas.
i think you dont know what you want, why you are publishing a post? and wasting time (check in bold text what you asked in first Quote)
by the way, buy from credit card go to http://www.streakwave.com very cheep, if you need any help for buy online? i can help you
Allah Hafiz
Are you making money? :open_mouth:
well the sector i overtook is on 3.20 level my home basestation is 4.16 both are legit. I want to replace the pc with a smaller box due to power conditions so i can run on ups with long backups.
will streakwave deliver the hardware to pakistan ??
yes they can
Mikrotik is not a only way to make money, but yes i am making good money with help of Mikrotik knowledge,
Thank you Mikrotik
