Anything in the below config can explain a connectivity/throughput slowdown?
Here’s the AX3 config:
# 2024-03-23 16:05:29 by RouterOS 7.14
# software id = 5NRD-V1QF
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDxxxxxx
add disabled=yes name=Guest-Bridge port-cost-mode=short
add admin-mac=48:A9:8A:0F:04:8F auto-mac=no comment=defconf name=bridge \
set [ find default-name=ether1 ] comment="To hEX" poe-out=off
set [ find default-name=ether3 ] comment=TV
set [ find default-name=ether4 ] comment=TV
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all \
.width=20/40mhz configuration.country="United States" .mode=ap .ssid=\
Upstairs5g-0F0493 disabled=no security.authentication-types=wpa2-psk \
.passphrase=PASSWORD
set [ find default-name=wifi2 ] channel.band=2ghz-n .skip-dfs-channels=all \
.width=20mhz configuration.country="United States" .mode=ap .ssid=\
Upstairs-2G-0F0494 disabled=no security.authentication-types=wpa2-psk \
add configuration.mode=ap .ssid=2point4 disabled=no mac-address=\
4A:A9:8A:0F:04:93 master-interface=wifi2 mtu=1500 name=Guest212 \
security.authentication-types=wpa2-psk,wpa3-psk .passphrase=PASSWORD
add comment=defconf name=WAN
add comment=defconf name=LAN
add include=LAN,WAN name=ALL-JRS
add name=TRUSTED
add name=dhcp_pool0 ranges=172.16.0.2-172.16.0.254
add address-pool=dhcp_pool0 interface=Guest-Bridge name=dhcp1
/ip smb users
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
add bridge=bridge interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=Guest212 internal-path-cost=10 path-cost=10
add bridge=bridge interface=*A internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=TRUSTED
/interface bridge vlan
add bridge=bridge vlan-ids=100
add interface=bridge list=TRUSTED
add interface=ether1 list=TRUSTED
add interface=wifi1 list=TRUSTED
add interface=wifi2 list=TRUSTED
/interface wifi access-list
add action=accept comment=HarmonyHub disabled=no mac-address=\
00:04:20:F9:31:D2
add action=accept comment=MFC-L3770 disabled=no mac-address=30:C9:AB:17:71:59
add action=accept comment="JRS iPhone" disabled=no mac-address=\
FC:AA:81:2A:1F:B4
add action=accept comment="\?\?\?" disabled=no mac-address=96:4E:A5:1A:A9:74
add action=accept comment="\?\?\?" disabled=no mac-address=52:DA:D4:46:23:5B
add action=accept comment="Thomas iPhone" disabled=no mac-address=\
46:B4:96:5E:1A:1B
add action=accept comment="SRN iPhone" disabled=no mac-address=\
4A:11:46:2B:5B:78
add action=accept comment="\?\?\?" disabled=no mac-address=02:2A:61:8A:88:A7
add action=accept comment="SRN iPad" disabled=no mac-address=\
16:31:50:11:6B:CF
add action=accept comment=DCP-L2550DW disabled=no mac-address=\
2C:6F:C9:5F:BC:EB
add action=accept comment=Laptop-JRS-AN51 disabled=no mac-address=\
94:E7:0B:29:30:E7
add action=accept comment="Tasmota switch" disabled=no mac-address=\
C4:5B:BE:E3:76:77
add action=accept comment="JRS Laptop 2023" disabled=no mac-address=\
64:49:7D:61:AE:2C
add action=accept comment="Living room (TV maybe)" disabled=no mac-address=\
D4:90:9C:D8:66:99
add action=accept comment="49TCLRokuTV - Thomas" disabled=no mac-address=\
0C:62:A6:1E:8B:18
add action=accept comment="SRN MS laptop" disabled=no mac-address=\
24:EE:9A:54:9A:E8
add action=accept comment=MFC-L2550 disabled=no mac-address=B2:38:0C:90:FE:04
add action=accept comment="THR316 Thomas BR" disabled=no mac-address=\
C8:F0:9E:E8:8A:E4
EA:C1:05:82:99:7C
add address=192.168.2.5/24 comment=defconf interface=bridge network=\
192.168.2.0
add address=10.10.10.5/24 disabled=yes interface=bridge network=10.10.10.0
add address=172.16.0.1/24 disabled=yes interface=Guest-Bridge network=\
172.16.0.0
/ip cloud
set ddns-enabled=yes
add address=172.16.0.0/24 gateway=172.16.0.1
set allow-remote-requests=yes cache-max-ttl=4w cache-size=32768KiB \
query-server-timeout=5s servers=192.168.2.2
/ip dns static
add address=192.168.2.5 comment=defconf name=hapax3.212.local
established,related,untracked disabled=yes
add action=accept chain=input disabled=yes
invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
disabled=yes in-interface-list=!LAN
add action=accept chain=forward disabled=yes in-interface-list=LAN log=yes
disabled=yes ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid disabled=yes
connection-state=new disabled=yes in-interface-list=WAN
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ip smb shares
set [ find default=yes ] directory=/pub
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=212hAP-Ax3
/system logging
add topics=wireless
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.2.2
add address=3.pool.ntp.org
add address=0.north-america.pool.ntp.org
/system scheduler
add interval=2d name=export-download on-event=export-download policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2023-02-01 start-time=16:44:58
add interval=2d name=dynamic-data-rextended on-event=dynamic-data-rextended \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2023-09-30 start-time=02:58:29
/system script
add dont-require-permissions=no name=export-download owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\r\
\n\r\
\n/system\r\
\n:local cdate [clock get date] \r\
\n:local yyyy [:pick \$cdate 0 4]\r\
\n:local MM [:pick \$cdate 5 7]\r\
\n:local dd [:pick \$cdate 8 10]\r\
\n:local identitydate \"\$[identity get name]_\$yyyy-\$MM-\$dd\"\r\
\n/export show-sensitive file=\"\$identitydate\"\r\
\n\r\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"/\$[\$identitydate].\
rsc\" dst-path=\"/mikrotik-backups/\$[\$identitydate].rsc\" address=192.16\
8.2.22 port=21 user=mikrotik password=PASSWORD\r\
\n\r\
\n/file remove \"\$[\$identitydate]\""
add dont-require-permissions=no name=dynamic-data-rextended owner=admin \
source="/system\r\
\n:local identitydate \"\$[identity get name]_\$[clock get date]\"\r\
\n:local stringexec \"/system iden print; :put \\\"\\\\r\\\\n\\\"; /ip c\
loud pri; :put \\\"\\\\r\\\\n\\\"; /ip dhcp-server lease pri det; :put \\\
\"\\\\r\\\\n\\\"; /int bridge host pri det\"\r\
\n\r\
\n:if ([:len [/system package find where name=\"wifiwave2\"]] > 1) do={\r\
\n :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wifiwav\
e2 reg pri det\"\r\
\n} \r\
\n\r\
\n :set stringexec \"\$stringexec; :put \\\"\\\\r\\\\n\\\" /int wireles\
s reg pri det\"\r\
\n}\r\
\n\r\
\n\r\
\n/file remove [find where name=tmpresults.txt]\r\
\n:delay 1s\r\
\n:execute \$stringexec file=tmpresults.txt\r\
\n:delay 2s\r\
\n\r\
\n/tool fetch upload=yes mode=ftp ascii=no address=192.168.2.22 port=21 us\
er=mikrotik password=PASSWORD \\\r\
\n src-path=tmpresults.txt dst-path=\"/mikrotik-backups/\$identitydate-\
dynamicdata.txt\"\r\
\n\r\
\n/file remove [find where name=tmpresults.txt]"
/tool graphing interface
add interface=wifi2
add
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=wifi1
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
set allowed-interface-list=TRUSTED
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool sniffer
set file-limit=10000KiB filter-mac-address=\
10:6F:D9:D4:AA:65/FF:FF:FF:FF:FF:FF memory-limit=1000KiB
Here is the RB5009 config:
# 2024-03-23 16:05:57 by RouterOS 7.14
# software id = 2KBD-7ZZB
# model = RB5009UPr+S+
# serial number = HDA0xxxxx
add admin-mac=18:FD:74:CF:7F:5D auto-mac=no comment=defconf name=bridge \
set [ find default-name=ether1 ] comment=WAN poe-out=off
set [ find default-name=ether2 ] comment="Switch CSS 24" poe-out=off
set [ find default-name=ether3 ] comment="JRS PC port 3" poe-out=off
set [ find default-name=ether4 ] comment="hAP 16" poe-out=off
set [ find default-name=ether5 ] comment="15 wall port 5 -- Proxmox" poe-out=\
off
set [ find default-name=ether6 ] comment="MOCA adapter" poe-out=off
set [ find default-name=ether7 ] poe-out=off
set [ find default-name=ether8 ] poe-out=off
/interface wireguard
add listen-port=51820 mtu=1420 name=212-Wireguard private-key=\
"WIPjxxxxA="
add name=MANAGE
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
/iot mqtt brokers
add address=192.168.0.103 client-id=192.168.2.2 name=HA password=PASSWORD \
username=mqtt
add address=192.168.0.162 auto-connect=yes name="Home Assistant" password=\
PASSWORD username=mqtt
add name=dhcp ranges=192.168.2.100-192.168.2.200
add address-pool=dhcp interface=bridge lease-script="\r\
\n/system\r\
\n\r\
\n:local thistime [/system clock get time]\r\
\n:local thishour [:pick \$thistime 0 2]\r\
\n:local thisminute [:pick \$thistime 3 5]\r\
\n:local thissecond [:pick \$thistime 6 8]\r\
\n:local identitydatetime \"\$[identity get name]_\$yyyy-\$MM-\$dd_\$thish\
our:\$thisminute:\$thissecond\"\r\
\n:local datetime \"\$yyyy-\$MM-\$dd_\$thishour:\$thisminute:\$thissecond\
\"\r\
\n:local systemname \"\$[identity get name]\"\r\
\n\r\
\n#:if (\$leaseBound=1) do={\r\
\n\r\
\n# :log info \"testing after condition BOUND\" }\r\
\n\r\
\n#:if ([/ip dhcp-server lease find where dynamic mac-address=\$leaseActM\
AC]!=\"\") do={\r\
\n\r\
\n# :log info \"testing after condition DYNAMIC\"}\r\
\n\r\
\n\r\
\n:if ((\$leaseBound=1) && ([/ip dhcp-server lease find where dynamic ma\
c-address=\$leaseActMAC]!=\"\") && ([/ip dhcp-server lease find where comm\
ent mac-address=\$leaseActMAC]=\"\")) do={\r\
\n\r\
\n# :log info \"testing after conditions BOUND and DYNAMIC and EMPTY CO\
MMENT\" \r\
\n\r\
\n:local recipient \"email@email.com\"\r\
\n\r\
\n :tool e-mail send to=\$recipient subject=\"\$systemname DHCP Lease A\
ssigned to \$leaseActMAC\" body=\"MAC address \$leaseActMAC received IP ad\
dress \$leaseActIP with a hostname of \$[/ip/dhcp-server/lease/get value-n\
ame=host-name [find where mac-address=\$leaseActMAC]] from DHCP Server \$l\
easeServerName on \$datetime from \$systemname with comment \$[/ip/dhcp-se\
rver/lease/get value-name=comment [find where mac-address=\$leaseActMAC]]\
\"\r\
\n\r\
\n\r\
\n# :log info \"Sent DHCP alert for MAC \$leaseActMAC\"\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n" lease-time=1d name=defconf
/ip smb users
/system logging action
set 3 remote=192.168.2.2
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
disabled=yes disabled=yes name=zt1 port=9993
/container config
set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=all
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
forward=no max-neighbor-entries=8192
add interface=bridge list=MANAGE
add interface=*B list=MANAGE
add interface=212-Wireguard list=LAN
add interface=212-Wireguard list=MANAGE
/interface wireguard peers
add allowed-address=10.10.100.8/32 comment="JRS Laptop" interface=\
212-Wireguard public-key="b9iyIPXw9MQIGo852yC/Xd9Ds2VQoOKASosTxjRpJX8="
add allowed-address=\
10.10.100.2/32,192.168.88.0/24,10.10.100.40/32,192.168.40.0/24 comment=\
371 endpoint-address=371.dyndns.org endpoint-port=52820 interface=\
212-Wireguard persistent-keepalive=40s public-key=\
"xxxxx="
add allowed-address=10.10.100.9/32 comment="JRS iPhone" interface=\
212-Wireguard public-key="xxxxxx/fkSuBAuOb/ZBIFY="
add allowed-address=10.10.100.12/32,192.168.20.0/24 comment=629 \
endpoint-address=aaaaa.dyndns.org endpoint-port=51821 interface=\
"xxxxxx="
add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 comment=355 \
endpoint-address=aaaaa.dyndns.org endpoint-port=51833 interface=\
"Q8CPJm+/xxxxxxx="
add allowed-address=10.10.100.60/32,192.168.1.0/24 comment=255 \
endpoint-address=aaaaa.dyndns.org endpoint-port=51835 interface=\
"xxxxxx+r9bzZ0aWPK0PMwbRc="
add allowed-address=10.10.100.30/32,192.168.30.0/24 comment=76 \
endpoint-address=aaaa.dyndns.org endpoint-port=51830 interface=\
"xxxxx="
add allowed-address=10.10.90.0/24 comment="BI PC WG APP" endpoint-port=51820 \
interface=212-Wireguard public-key=\
"xxxxxx/RFr9FogUr5iBSC0jt9TV4="
add allowed-address=10.10.100.1/32,192.168.2.2/24 comment=\
"212 (local, just for reference); 192.168.2.2" disabled=yes \
endpoint-address=AAAA.dyndns.org endpoint-port=51820 interface=\
212-Wireguard public-key="xxxxxx/op1OqXrW4Ds="
add allowed-address=10.10.100.100/32 comment="JRS Laptop 201" disabled=yes \
"QJCXZaf5K/xxxx="
add allowed-address=10.10.100.101/32 endpoint-port=51840 interface=\
212-Wireguard public-key="N/t6/86S/xxxxx="
add allowed-address=10.10.100.70/32,192.168.70.0/24 comment=125 \
endpoint-address=AAAA.dyndns.org endpoint-port=51870 interface=\
"xxxxx="
add allowed-address=10.10.100.99/32,192.168.2.0/24 comment="JRS Laptop 2023" \
interface=212-Wireguard private-key=\
"ED8Ig6UntTB7Kg+xxxx//vOc9p2Q=" public-key=\
"w9XFUjODaOIOQbCeMVJ+xxxx="
add allowed-address=10.10.100.53/32,192.168.0.0/24 client-listen-port=51840 \
comment="WG Proxmox Win11" endpoint-address=aaaaa.dyndns.org \
endpoint-port=51844 interface=*12 public-key=\
"Wut4NWWjMvqM+xxxx+xxxx="
add address=192.168.2.2/24 comment=defconf interface=bridge network=\
192.168.2.0
add address=10.10.100.1/24 interface=212-Wireguard network=10.10.100.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server alert
add alert-timeout=30m interface=bridge on-alert=rogue-dhcp
add address=192.168.2.100 comment=TV15 mac-address=78:6A:1F:8D:F9:C8 server=\
defconf
add address=192.168.2.121 client-id=1:da:f3:68:be:3f:b comment="Ipad SRN" \
mac-address=DA:F3:68:BE:3F:0B server=defconf
add address=192.168.2.102 comment=STB mac-address=78:6A:1F:8D:FC:B4 server=\
defconf
add address=192.168.2.101 comment=STB mac-address=78:6A:1F:8D:FC:0F server=\
defconf
add address=192.168.2.103 comment=STB mac-address=A0:68:7E:4D:D0:4B server=\
defconf
add address=192.168.2.138 client-id=1:30:c9:ab:17:71:59 comment=MFCL3770CDW \
lease-time=3d18h mac-address=30:C9:AB:17:71:59 server=defconf
add address=192.168.2.107 client-id=1:94:e7:b:29:30:e7 comment=JRSLaptopASUS \
mac-address=94:E7:0B:29:30:E7 server=defconf
add address=192.168.2.141 client-id=1:c2:5d:7f:1f:4c:f5 comment="JRS iPhone" \
mac-address=C2:5D:7F:1F:4C:F5 server=defconf
add address=192.168.2.106 client-id=1:18:fd:74:cf:7f:5c comment=RB5009 \
mac-address=18:FD:74:CF:7F:5C server=defconf
add address=192.168.2.109 client-id=1:0:6b:9e:d1:24:f3 comment="Vizio on 15" \
mac-address=00:6B:9E:D1:24:F3 server=defconf
add address=192.168.2.147 comment=TV mac-address=3C:59:1E:F4:02:EF server=\
defconf
add address=192.168.2.122 client-id=1:d4:90:9c:d8:66:99 comment=Homepod \
mac-address=D4:90:9C:D8:66:99 server=defconf
add address=192.168.2.191 comment="TV 15 SRN Office" mac-address=\
3C:59:1E:F4:3C:CB server=defconf
add address=192.168.2.199 client-id=1:c8:63:f1:f1:9f:44 comment=Playstation \
mac-address=C8:63:F1:F1:9F:44 server=defconf
add address=192.168.2.119 client-id=1:88:e9:fe:6e:97:9d comment=ThomasMBP \
mac-address=88:E9:FE:6E:97:9D server=defconf
add address=192.168.2.128 comment=MBR65TV mac-address=34:51:80:C8:BB:2C \
server=defconf
add address=192.168.2.200 client-id=1:0:4:20:f9:31:d2 comment=HarmonyHub \
lease-time=3d18h mac-address=00:04:20:F9:31:D2 server=defconf
add address=192.168.2.114 client-id=1:46:b4:96:5e:1a:1b comment=\
"Thomas iPhone" mac-address=46:B4:96:5E:1A:1B server=defconf
add address=192.168.2.176 client-id=1:18:3:73:3a:63:19 mac-address=\
18:03:73:3A:63:19 server=defconf
add address=192.168.2.142 client-id=1:4e:fe:92:a6:40:cd comment=SRNAppleWatch \
mac-address=4E:FE:92:A6:40:CD server=defconf
add address=192.168.2.124 client-id=1:2c:6f:c9:5f:bc:eb comment=Printer \
mac-address=2C:6F:C9:5F:BC:EB server=defconf
add address=192.168.2.173 client-id=1:24:ee:9a:54:9a:e8 comment=NC-LT-SN20 \
mac-address=24:EE:9A:54:9A:E8 server=defconf
add address=192.168.2.117 client-id=1:b4:22:0:95:59:8a comment=Printer \
mac-address=B4:22:00:95:59:8A server=defconf
add address=192.168.2.127 client-id=\
ff:a1:71:46:7d:0:1:0:1:2c:cb:11:8c:a:25:a1:71:46:7d comment=\
"Debian LXC under Proxmox" mac-address=0A:25:A1:71:46:7D server=defconf
add address=192.168.2.110 client-id=1:64:49:7d:61:ae:2c comment=\
JRS-Laptop-2023 mac-address=64:49:7D:61:AE:2C server=defconf
add address=192.168.2.166 comment="15 TV" mac-address=B0:A7:37:75:B6:60 \
server=defconf
add address=192.168.2.105 client-id=1:c4:17:fe:43:33:7 comment=Susans-iPhone \
mac-address=C4:17:FE:43:33:07 server=defconf
add address=192.168.2.108 client-id=1:0:5:cd:19:3c:7 comment="Denon AVR" \
mac-address=00:05:CD:19:3C:07 server=defconf
add address=192.168.2.116 client-id=1:ea:c1:5:82:99:7c comment="SRN iphone" \
mac-address=EA:C1:05:82:99:7C server=defconf
add address=192.168.2.120 client-id=1:96:4e:a5:1a:a9:74 comment=\
"Thomas iPad large" mac-address=96:4E:A5:1A:A9:74 server=defconf
add address=192.168.2.123 client-id=1:54:6c:eb:7b:a2:c3 comment="Thomas Acer" \
mac-address=54:6C:EB:7B:A2:C3 server=defconf
add address=192.168.2.113 client-id=1:18:fd:74:38:81:2b comment=hEX \
mac-address=18:FD:74:38:81:2B server=defconf
add address=192.168.2.112 client-id=1:fc:aa:81:2a:1f:b4 comment=\
"JRS iPhone 2023" mac-address=FC:AA:81:2A:1F:B4 server=defconf
add address=192.168.2.118 client-id=1:36:41:ef:17:d0:c9 comment=\
"SRN Apple Watch" mac-address=36:41:EF:17:D0:C9 server=defconf
add address=192.168.2.115 client-id=1:16:31:50:11:6b:cf comment="Susan iPad" \
mac-address=16:31:50:11:6B:CF server=defconf
add address=192.168.2.126 client-id=1:7a:49:88:57:e9:14 comment=\
"NOT any Thomas or Susan's Device" mac-address=7A:49:88:57:E9:14 server=\
defconf
add address=192.168.2.130 client-id=1:3c:6:30:20:1:70 comment="Padan\?" \
mac-address=3C:06:30:20:01:70 server=defconf
add address=192.168.2.133 client-id=1:f6:b9:88:dd:23:1a comment="\?\?\?\?\?" \
mac-address=F6:B9:88:DD:23:1A server=defconf
add address=192.168.2.134 client-id=1:be:22:c3:46:12:33 mac-address=\
BE:22:C3:46:12:33 server=defconf
add address=192.168.2.111 client-id=1:c8:f0:9e:e8:8a:e4 comment=\
"THR316D T BR" mac-address=C8:F0:9E:E8:8A:E4 server=defconf
add address=192.168.2.131 client-id=1:d6:a9:86:b1:c9:3e comment="SRN iwatch" \
mac-address=D6:A9:86:B1:C9:3E server=defconf
add address=192.168.2.129 client-id=1:22:bc:d8:7f:66:fd comment="Thomas -- " \
mac-address=22:BC:D8:7F:66:FD server=defconf
add address=192.168.2.132 client-id=1:3c:a6:f6:1f:87:ac mac-address=\
3C:A6:F6:1F:87:AC server=defconf
add address=192.168.2.139 client-id=1:1a:b9:14:b4:55:ea comment=\
"Rachel phone" mac-address=1A:B9:14:B4:55:EA server=defconf
add address=192.168.2.140 client-id=1:68:1d:ef:38:e5:9b comment=\
"Mini-PC from aliexpress" mac-address=68:1D:EF:38:E5:9B server=defconf
add address=192.168.2.125 client-id=1:2e:ef:fe:36:a1:5 comment=\
"Thomas iPhone" mac-address=2E:EF:FE:36:A1:05 server=defconf
add address=192.168.2.137 client-id=1:c8:7f:54:5a:69:13 comment=\
"JRS 2024 Desktop" mac-address=C8:7F:54:5A:69:13 server=defconf
add address=192.168.2.144 client-id=1:3c:6:30:c:ee:88 mac-address=\
3C:06:30:0C:EE:88 server=defconf
add address=192.168.2.154 comment=65TCLRokuTV mac-address=08:C3:B3:DF:26:62 \
server=defconf
add address=192.168.2.171 comment=49TCLRokuTV mac-address=0C:62:A6:1E:8B:18 \
server=defconf
add address=192.168.2.149 client-id=1:68:1d:ef:3a:da:e0 comment=\
"T8-Mini-PC-26NNQ3ARVB1\r\
\n" mac-address=68:1D:EF:3A:DA:E0 server=defconf
add address=192.168.2.143 client-id=1:b2:38:c:90:fe:4 comment=MFC-L2550 \
mac-address=B2:38:0C:90:FE:04 server=defconf
add address=192.168.2.161 client-id=1:ec:da:3b:d1:92:3c comment=\
"Presence sensor Screek D1923C" mac-address=EC:DA:3B:D1:92:3C server=\
defconf
add address=192.168.2.190 mac-address=48:55:19:F0:73:12 server=defconf
add address=192.168.2.150 client-id=1:84:57:33:9b:83:85 mac-address=\
84:57:33:9B:83:85 server=defconf
add address=192.168.2.162 client-id=1:7c:4b:26:5d:6:be mac-address=\
7C:4B:26:5D:06:BE server=defconf
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.2 gateway=\
192.168.2.2 netmask=24
set allow-remote-requests=yes cache-max-ttl=8w4d cache-size=65536KiB servers=\
1.1.1.1,1.0.0.1,8.8.8.8,9.9.9.9
/ip dns static
add address=192.168.2.8 name=212-rb5009.212.local
add address=192.168.2.2 name=RB5009.212.local ttl=9w6d10h40m
add address=10.10.100.1 name=212.10.10.100.1.local ttl=9w6d10h40m
add address=192.168.2.100 comment="automatic-from-comment (magic comment)" \
name=TV15.212.local ttl=1h
add address=192.168.2.121 comment="automatic-from-comment (magic comment)" \
name="Ipad SRN.212.local" ttl=9w6d10h40m
add address=192.168.2.138 comment="automatic-from-comment (magic comment)" \
name=MFCL3770CDW.212.local ttl=9w6d10h40m
add address=192.168.2.141 comment="automatic-from-comment (magic comment)" \
name="JRS iPhone.212.local" ttl=9w6d10h40m
add address=192.168.2.109 comment="automatic-from-comment (magic comment)" \
name="Vizio on 15.212.local" ttl=9w6d10h40m
add address=192.168.2.122 comment="automatic-from-comment (magic comment)" \
name=Homepod.212.local ttl=9w6d10h40m
add address=192.168.2.199 comment="automatic-from-comment (magic comment)" \
name=Playstation.212.local ttl=9w6d10h40m
add address=192.168.2.142 comment="automatic-from-comment (magic comment)" \
name=SRNAppleWatch.212.local ttl=9w6d10h40m
add address=192.168.2.22 name=JRS-PC.212.local
add address=192.168.2.102 comment="automatic-from-dhcp (magic comment)" name=\
Master-Bedroom.212.local ttl=1h40m
add address=192.168.2.103 comment="automatic-from-dhcp (magic comment)" name=\
Family-Room.212.local ttl=1h40m
add address=192.168.2.138 comment="automatic-from-dhcp (magic comment)" name=\
MFC-L3770.212.local ttl=1h40m
add address=192.168.2.147 comment="automatic-from-dhcp (magic comment)" name=\
212LR.212.local ttl=1h40m
add address=192.168.2.191 comment="automatic-from-dhcp (magic comment)" name=\
SRNOffice.212.local ttl=1h40m
add address=192.168.2.128 comment="automatic-from-dhcp (magic comment)" name=\
212MBR.212.local ttl=1h40m
add address=192.168.2.200 comment="automatic-from-dhcp (magic comment)" name=\
HarmonyHub.212.local ttl=1h40m
add address=192.168.2.124 comment="automatic-from-dhcp (magic comment)" name=\
BRW2C6FC95FBCEB.212.local ttl=1h40m
add address=192.168.2.173 comment="automatic-from-dhcp (magic comment)" name=\
NC-LT-SN20.212.local ttl=1h40m
add address=192.168.2.137 comment="automatic-from-dhcp (magic comment)" name=\
tasmota-E37677-5751.212.local ttl=1h40m
add address=192.168.2.117 comment="automatic-from-dhcp (magic comment)" name=\
BRNB4220095598A.212.local ttl=1h40m
add address=192.168.2.127 comment="automatic-from-dhcp (magic comment)" name=\
Debian.212.local ttl=1h40m
add address=192.168.2.110 comment="automatic-from-dhcp (magic comment)" name=\
JRS-Laptop-2023.212.local ttl=1h40m
add address=192.168.2.108 comment="automatic-from-dhcp (magic comment)" name=\
0005CD193C07.212.local ttl=1h40m
/ip firewall address-list
add address=AAAA.dyndns.org list=dynamic-WANIP
add address=192.168.0.0/16 list=Authorized
add address=10.10.100.0/24 list=Authorized
invalid
add action=accept chain=input comment="Loopback allow" dst-address=127.0.0.1
add action=accept chain=input comment="Allow incoming WG connections" \
dst-port=51820 protocol=udp
add action=accept chain=input comment="Allow Authorized" src-address-list=\
Authorized
add action=accept chain=input comment="Allow LAN" in-interface-list=LAN
add action=drop chain=input comment="drop all else"
add action=accept chain=forward comment="Allow LAN to WAN" in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat
add action=accept chain=forward comment="Allows cross peer subnet traffic" \
in-interface=212-Wireguard out-interface=212-Wireguard
add action=accept chain=forward comment="Allow WG to subnet" dst-address=\
192.168.2.0/24 in-interface=212-Wireguard
add action=accept chain=forward comment="Allow all traffic out WG iface" \
add action=drop chain=forward log=yes
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
"Mark connection for hairpin" disabled=yes dst-address-list=dynamic-WANIP \
log=yes new-connection-mark="Hairpin NAT" passthrough=yes src-address=\
192.168.2.0/24
192.168.2.0/24
192.168.2.0/24
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark=\
"Hairpin NAT" dst-address=192.168.2.0/24 src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="NEW defconf: masquerade" \
add action=dst-nat chain=dstnat dst-address-list=dynamic-WANIP dst-port=8123 \
protocol=tcp to-addresses=192.168.2.176
add action=dst-nat chain=dstnat disabled=yes dst-address-list=dynamic-WANIP \
dst-port=8123 protocol=tcp to-addresses=192.168.2.176
dst-port=5911 log=yes protocol=tcp to-addresses=192.168.2.139
add action=dst-nat chain=dstnat disabled=yes dst-port=51833 protocol=udp \
to-addresses=192.168.2.50
add comment=371 disabled=yes distance=1 dst-address=192.168.88.0/24 gateway=\
*B pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add comment=355 disabled=yes distance=1 dst-address=192.168.0.0/24 gateway=*B \
target-scope=10
add comment=255 disabled=yes distance=1 dst-address=192.168.1.0/24 gateway=*B \
target-scope=10
add disabled=yes distance=1 dst-address=192.168.5.0/24 gateway=*B pref-src="" \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add comment=629 disabled=yes distance=1 dst-address=192.168.20.0/24 gateway=\
target-scope=10
target-scope=10
add comment=355 disabled=no distance=1 dst-address=192.168.0.0/24 gateway=\
212-Wireguard pref-src="" routing-table=main scope=30 \
add comment=255 disabled=no distance=1 dst-address=192.168.1.0/24 gateway=\
add comment=355-Cameras disabled=no distance=1 dst-address=192.168.5.0/24 \
gateway=212-Wireguard pref-src="" routing-table=main scope=30 \
add comment=629 disabled=no distance=1 dst-address=192.168.20.0/24 gateway=\
add disabled=no distance=1 dst-address=192.168.60.0/24 gateway=192.168.2.8 \
target-scope=10
add comment=76 disabled=no distance=1 dst-address=192.168.30.0/24 gateway=\
add comment=371 disabled=no distance=1 dst-address=192.168.40.0/24 gateway=\
add comment=125 disabled=no distance=1 dst-address=192.168.70.0/24 gateway=\
/ip smb shares
/snmp
/system clock
/system identity
set name=212RB5009
/system logging
add disabled=yes topics=dude
add disabled=yes topics=wireguard
add disabled=yes topics=interface
add action=echo disabled=yes topics=wireguard
add disabled=yes topics=debug
add disabled=yes topics=mqtt
add topics=account
add disabled=yes topics=firewall
add disabled=yes topics=dhcp
/system note
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
add address=216.239.35.4
add address=104.16.132.229
/system scheduler
add disabled=yes interval=1d name=Daily on-event=dyndns policy=\
start-date=2022-10-18 start-time=02:00:00
add disabled=yes interval=10m name=Route355255371 on-event=\
"355 255 371 route status" policy=\
start-date=2022-11-24 start-time=04:42:54
add interval=4d name=export-download on-event=export-download policy=\
start-date=2022-12-14 start-time=04:47:33
add disabled=yes interval=1h name="355 255 371 629 Route Status" on-event=\
"355 255 371 629 Route Status" policy=\
start-date=2023-01-23 start-time=16:22:48
add interval=2d name=DynDNS on-event=DynDNS policy=\
add interval=30m name=Netwatch on-event=Netwatch policy=\
add interval=30m name=WG-iface-restart on-event=WG-iface-restart policy=\
start-date=2023-03-13 start-time=06:41:55
add interval=5d name=IPlist on-event=IPlist policy=\
start-date=2023-04-10 start-time=06:54:16
add disabled=yes name="Hassio Firmware Entity Publish" on-event=\
"Hassio Firmware Entity Publish" policy=read,test start-time=startup
add disabled=yes interval=6h name="Hassio Firmware State Publish" on-event=\
"Hassio Firmware State Publish" policy=read,write,policy,test start-time=\
startup
add disabled=yes name=HassioSensorHealthEntityPublish on-event=\
HassioSensorHealthEntityPublish policy=read,write,test start-time=startup
add disabled=yes interval=1h name=HassioSensorHealthStatePublish on-event=\
HassioSensorHealthStatePublish policy=read,write,test start-time=startup
add disabled=yes name=HassioSensorPoeEntityPublish on-event=\
HassioSensorPoeEntityPublish policy=read,write,test start-time=startup
add disabled=yes interval=1h name=HassioSensorPoeStatePublish on-event=\
HassioSensorPoeStatePublish policy=read,test start-time=startup
add interval=1d name=dhcpleasesftp on-event=dhcpleasesftp policy=\
add interval=30m name=WG-iface-restart-log-lasthandshake on-event=\
WG-iface-restart-log-lasthandshake policy=\
start-date=2024-03-18 start-time=05:25:18
/system script
add dont-require-permissions=no name=DynDNS owner=admin policy=\
\r\
\n/system\r\
\n#/export show-sensitive file=\"\$identitydate\"\r\
\n\r\
\n# Export public IP and mail it\r\
\n\r\
\n/ip/address print file=\"\$identitydate-IP\"\r\
\n\r\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"\$[\$identitydate]-I\
P.txt\" dst-path=\"/mikrotik-backups/\$[\$identitydate]-IP.txt\" address=1\
92.168.2.22 port=21 user=mikrotik password=PASSWORD\r\
\n\r\
\n/file remove \"\$identitydate-IP.txt\"\r\
\n\r\
\n# Set needed variables\r\
\n\t:local username \"AAAA\"\r\
\n\t:local clientkey \"9ac4f32e2bba11e788e206873aa78bc3\"\r\
\n\t:local hostname \"AAAA.dyndns.org\"\r\
\n\r\
\n\t:global dyndnsForce\r\
\n\t:global previousIP\r\
\n\r\
\n# get the current IP address from the internet (in case of double-nat)\r\
\n\t/tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" ds\
t-path=\"/dyndns.checkip.html\"\r\
\n\t:delay 1\r\
\n\t:local result [/file get dyndns.checkip.html contents]\r\
\n\r\
\n# parse the current IP result\r\
\n\t:local resultLen [:len \$result]\r\
\n\t:local startLoc [:find \$result \": \" -1]\r\
\n\t:set startLoc (\$startLoc + 2)\r\
\n\t:local endLoc [:find \$result \"</body>\" -1]\r\
\n\t:local currentIP [:pick \$result \$startLoc \$endLoc]\r\
\n\t:log info \"UpdateDynDNS: currentIP = \$currentIP\"\r\
\n\r\
\n# Remove the # on next line to force an update every single time - usefu\
l for debugging,\r\
\n# but you could end up getting blacklisted by DynDNS!\r\
\n\r\
\n#:set dyndnsForce true\r\
\n\r\
\n# Determine if dyndns update is needed\r\
\n# more dyndns updater request details https://help.dyn.com/remote-access\
-api/perform-update/\r\
\n\t:log info \"UpdateDynDNS: previousIP = \$previousIP\"\r\
\n\t:if (\$dyndnsForce = true) do={ :log warning \"UpdateDynDNS: Forced up\
date on\" }\r\
\n\r\
\n\t:if ((\$currentIP != \$previousIP) || (\$dyndnsForce = true)) do={\r\
\n\t\t:set dyndnsForce false\r\
\n\t\t:set previousIP \$currentIP\r\
\n\r\
\n\t\t/tool fetch mode=https \\\r\
\n\t\turl=\"https://\$username:\$clientkey@members.dyndns.org/v3/update\?h\
ostname=\$hostname&myip=\$currentIP\" \\ \r\
\n\t\tdst-path=\"/dyndns.txt\"\r\
\n\r\
\n\t\t:delay 1\r\
\n\t\t:local result [/file get dyndns.txt contents]\r\
\n\t\t:log info (\"UpdateDynDNS: Dyndns update needed\")\r\
\n\t\t:log info (\"UpdateDynDNS: Dyndns Update Result: \".\$result)\r\
\n\t\t:put (\"Dyndns Update Result: \".\$result)\r\
\n\t} else={\r\
\n\t\t:log info (\"UpdateDynDNS: No dyndns update needed\")\r\
\n\t}\r\
\n\r\
\n"
add dont-require-permissions=no name=Netwatch owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\
\r\
\n:global prevstatus355;\r\
\n:global updown355;\r\
\n:global status355 [:ip route get value-name=active [:ip route find comme\
nt=\"355\"]]\r\
\n\r\
\n#:log info (\"status355 is \$status355\");\r\
\n#:log info (\"prevstatus355 is \$prevstatus355\");\r\
\n\r\
\n:if ( \"\$status355\" = true ) do={:set updown355 UP} else= {:set updown\
355 DOWN}\r\
\n\r\
\n#:log info (\"updown355 is \$updown355\");\r\
\n\r\
\n:if ( \"\$status355\" != \"\$prevstatus355\" ) do={ \r\
\n\r\
\n#:log warn \"355 connectivity is now \\\"\$updown355\\\" \";\r\
\n:tool e-mail send to=email@email.com subject=\"355 Connectivity n\
ow \\\"\$updown355\\\"\" body=( [ :system clock get date ] . \" \" . [ :sy\
stem clock get time ] . \" SENT FROM 212hEX: 355 connectivity changed sta\
tus from \\\"\$prevstatus355\\\" -> \\\"\$updown355\\\" \" )\r\
\n\r\
\n:set prevstatus355 \$status355\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n:global prevstatus371;\r\
\n:global updown371;\r\
\n:global status371 [:ip route get value-name=active [:ip route find comme\
nt=\"371\"]]\r\
\n\r\
\n#:log info (\"status371 is \$status371\");\r\
\n#:log info (\"prevstatus371 is \$prevstatus371\");\r\
\n\r\
\n:if ( \"\$status371\" = true ) do={:set updown371 UP} else= {:set updown\
371 DOWN}\r\
\n\r\
\n#:log info (\"updown371 is \$updown371\");\r\
\n\r\
\n:if ( \"\$status371\" != \"\$prevstatus371\" ) do={ \r\
\n\r\
\n#:log warn \"371 connectivity is now \\\"\$updown371\\\" \";\r\
\n:tool e-mail send to=email@email.com subject=\"371 Connectivity n\
ow \\\"\$updown371\\\"\" body=( [ :system clock get date ] . \" \" . [ :sy\
stem clock get time ] . \" SENT FROM 212hEX: 371 connectivity changed sta\
tus from \\\"\$prevstatus371\\\" -> \\\"\$updown371\\\" \" )\r\
\n\r\
\n:set prevstatus371 \$status371\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n:global prevstatus255;\r\
\n:global updown255;\r\
\n:global status255 [:ip route get value-name=active [:ip route find comme\
nt=\"255\"]]\r\
\n\r\
\n#:log info (\"status255 is \$status255\");\r\
\n#:log info (\"prevstatus255 is \$prevstatus255\");\r\
\n\r\
\n:if ( \"\$status255\" = true ) do={:set updown255 UP} else= {:set updown\
255 DOWN}\r\
\n\r\
\n#:log info (\"updown255 is \$updown255\");\r\
\n\r\
\n:if ( \"\$status255\" != \"\$prevstatus255\" ) do={ \r\
\n\r\
\n#:log warn \"255 connectivity is now \\\"\$updown255\\\" \";\r\
\n:tool e-mail send to=email@email.com subject=\"255 Connectivity n\
ow \\\"\$updown255\\\"\" body=( [ :system clock get date ] . \" \" . [ :sy\
stem clock get time ] . \" SENT FROM 212hEX: 255 connectivity changed sta\
tus from \\\"\$prevstatus255\\\" -> \\\"\$updown255\\\" \" )\r\
\n\r\
\n:set prevstatus255 \$status255\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n\r\
\n:global prevstatus629;\r\
\n:global updown629;\r\
\n:global status629 [:ip route get value-name=active [:ip route find comme\
nt=\"629\"]]\r\
\n\r\
\n#:log info (\"status629 is \$status629\");\r\
\n#:log info (\"prevstatus629 is \$prevstatus629\");\r\
\n\r\
\n:if ( \"\$status629\" = true ) do={:set updown629 UP} else= {:set updown\
629 DOWN}\r\
\n\r\
\n#:log info (\"updown629 is \$updown629\");\r\
\n\r\
\n:if ( \"\$status629\" != \"\$prevstatus629\" ) do={ \r\
\n\r\
\n#:log warn \"629 connectivity is now \\\"\$updown629\\\" \";\r\
\n:tool e-mail send to=email@email.com subject=\"629 Connectivity n\
ow \\\"\$updown629\\\"\" body=( [ :system clock get date ] . \" \" . [ :sy\
stem clock get time ] . \" SENT FROM 212hEX: 629 connectivity changed sta\
tus from \\\"\$prevstatus629\\\" -> \\\"\$updown629\\\" \" )\r\
\n\r\
\n:set prevstatus629 \$status629\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n:global prevstatus76;\r\
\n:global updown76;\r\
\n:global status76 [:ip route get value-name=active [:ip route find commen\
t=\"76\"]]\r\
\n\r\
\n#:log info (\"status76 is \$status76\");\r\
\n#:log info (\"prevstatus76 is \$prevstatus76\");\r\
\n\r\
\n:if ( \"\$status76\" = true ) do={:set updown76 UP} else= {:set updown76\
\_DOWN}\r\
\n\r\
\n#:log info (\"updown76 is \$updown76\");\r\
\n\r\
\n:if ( \"\$status76\" != \"\$prevstatus76\" ) do={ \r\
\n\r\
\n:tool e-mail send to=email@email.com subject=\"76 Connectivity no\
w \\\"\$updown76\\\"\" body=( [ :system clock get date ] . \" \" . [ :syst\
em clock get time ] . \" SENT FROM 212hEX: 76 connectivity changed status\
\_from \\\"\$prevstatus76\\\" -> \\\"\$updown76\\\" \" )\r\
\n\r\
\n:set prevstatus76 \$status76\r\
\n\r\
\n}\r\
\n\r\
\n\r\
\n}\r\
\n"
add dont-require-permissions=no name=GetIP owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
interface bridge host\r\
\n:foreach item in=[find] do={\r\
\n :local iface [get \$item interface]\r\
\n :local macadd [get \$item mac-address]\r\
\n :local idmac [/ip arp find where mac-address=\$macadd]\r\
\n :if ([:len \$idmac] = 1) do={\r\
\n :local ifip [/ip arp get \$idmac address]\r\
\n :put \"interface=\$iface mac=\$macadd ip=\$ifip\"\r\
\n }\r\
\n}"
add dont-require-permissions=no name="New route UP" owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
global prevstatus355\r\
\n{\r\
\n /ip route\r\
\n :local status355 [get [find where comment=\"355\"] active]\r\
\n :if (\$status355) do={:set status355 \"UP\"} else={:set status355 \"\
DOWN\"}\r\
\n :log info \"status355 is \$status355 and prevstatus355 is \$prevstat\
us355\"\r\
\n :if (\$status355 != \$prevstatus355) do={ \r\
\n :log warning \"355 connectivity is now \$status355\"\r\
\n /tool e-mail send to=email@email.com subject=\"355 Connec\
tivity is now \$status355\" \\\r\
\n body=\"\$[/system clock get date] \$[/system clock \
get time] 355 connectivity changed status \$prevstatus355 -> \$status355\"\
\r\
\n :set prevstatus355 \$status355\r\
\n }\r\
\n}\r\
\n"
\r\
\n\r\
\n/system\r\
\n\r\
\n\r\
\n/file remove \"\$identitydate.rsc\""
add dont-require-permissions=yes name=WG-iface-restart owner=admin policy=\
foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-a\
ddress~\"[a-z]\\\$\"] do={\r\
\n :local LastHandshake [/interface/wireguard/peers/get \$i last-handshak\
e]\r\
\n\r\
\n# :if (([:tostr \$LastHandshake] = \"\") or (\$LastHandshake > [:totime\
\_\"5m\"])) do={\r\
\n \r\
\n :if ((\$LastHandshake > [:totime \"5m\"])) do={ \r\
\n /interface/wireguard/peers/set \$i endpoint-address=[/interface/wire\
guard/peers/get \$i endpoint-address]\r\
\n\r\
\n :local endpoint [/interface/wireguard/peers/get \$i endpoint-address]\
\r\
\n :log info \"WG-iface-restart script found WG peer with last handshake\
\_greater than 5 minutes; then reset the endpoint-address to reload dns of\
\_endpoint: \$endpoint\"\r\
\n\r\
\n }\r\
\n}\r\
\n\r\
\n"
add dont-require-permissions=no name=IPlist owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
\_Export public IP and mail it\r\
\n\r\
\n/ip/address print file=\"212-IP-\$[\$nowdate]\"\r\
\n\r\
\n/tool fetch upload=yes mode=ftp ascii=no src-path=\"212-IP-\$[\$nowdate]\
.txt\" dst-path=\"/mikrotik-backups/212-IP-\$[\$nowdate].txt\" address=192\
\n\r\
\n/file remove \"212-IP-\$[\$nowdate].txt\""
add dont-require-permissions=no name="DHCP to DNS" owner=admin policy=\
\_SPDX-License-Identifier: CC0-1.0\
\n\r\
\n\r\r\r\r\
\n\r\
\n\r\r:local domains [:toarray \"212.local\"]\
\n\r\
\n\r\r:local dnsttl \"100m\"\
\n\r\
\n\r\r\
\n\r\
\n\r\r:local magiccomment \"automatic-from-dhcp (magic comment)\"\
\n\r\
\n\r\r:local activehosts [:toarray \"\"]\
\n\r\
\n\r\r\
\n\r\
\n\r\r:foreach lease in [/ip dhcp-server lease find] do={\
\n\r\
\n\r\r :local hostname [/ip dhcp-server lease get value-name=host-name \$\
lease]\
\n\r\
\n\r\r :local hostaddr [/ip dhcp-server lease get value-name=address \$le\
ase]\
\n\r\
\n\r\r\
\n\r\
\n\r\r :if ([:len \$hostname] > 0) do={\
\n\r\
\n\r\r :foreach domain in \$domains do={\
\n\r\
\n\r\r :local regdomain \"\$hostname.\$domain\"\
\n\r\
\n\r\r :set activehosts (\$activehosts, \$regdomain)\
\n\r\
\n\r\r\
\n\r\
\n\r\r :if ([:len [/ip dns static find where name=\$regdomain]] = 0) \
do={\
\n\r\
\n\r\r /ip dns static add name=\$regdomain address=\$hostaddr comme\
nt=\$magiccomment ttl=\$dnsttl\
\n\r\
\n\r\r } else={\
\n\r\
\n\r\r :if ([:len [/ip dns static find where name=\$regdomain comme\
nt=\$magiccomment]] = 1) do={\
\n\r\
\n\r\r /ip dns static set address=\$hostaddr [/ip dns static find\
\_name=\$regdomain comment=\$magiccomment]\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r}\
\n\r\
\n\r\r\
\n\r\
\n\r\r:foreach dnsentry in [/ip dns static find where comment=\$magiccomme\
nt] do={\
\n\r\
\n\r\r :local hostname [/ip dns static get value-name=name \$dnsentry]\
\n\r\
\n\r\r :if ([:type [:find \$activehosts \$hostname]] = \"nil\") do={\
\n\r\
\n\r\r /ip dns static remove \$dnsentry\
\n\r\
\n\r\r }\
\n\r\
\n\r\r}\
\n\r\
\n\r\r"
add dont-require-permissions=no name="Comment to DNS" owner=admin policy=\
\n\r\
\n\r\r\r\r\
\n\r\
\n\r\
\n\r\r:local dnsttl \"15m\"\
\n\r\
\n\r\r\
\n\r\
\n\r\r:local magiccomment \"automatic-from-comment (magic comment)\"\
\n\r\
\n\r\
\n\r\r\
\n\r\
\n\r\
\n\r\r :local hostname [/ip dhcp-server lease get value-name=comment \$le\
ase]\
\n\r\
ase]\
\n\r\
\n\r\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n\r\r\
\n\r\
do={\
\n\r\
\n\r\
\n\r\r } else={\
\n\r\
\n\r\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r }\
\n\r\
\n\r\r}\
\n\r\
\n\r\r\
\n\r\
nt] do={\
\n\r\
\n\r\
\n\r\
\n\r\
\n\r\r }\
\n\r\
\n\r\r}\
\n\r\
\n\r\r"
add dont-require-permissions=no name="Get dhcp-client gatewat" owner=admin \
source="\r\
\n:local dhcpclientGW [/ip dhcp-client get [find interface=ether1] gatewa\
y]\r\
\n\r\
\n:log info \$dhcpclientGW\r\
\n"
source="/system\r\
\n\r\
e2 reg pri det\"\r\
\n} \r\
\n\r\
s reg pri det\"\r\
\n}\r\
\n\r\
\n\r\
\n:delay 1s\r\
\n:delay 2s\r\
\n\r\
\n\r\
add dont-require-permissions=no name="mqtt to HA" owner=admin policy=\
system script add dont-require-permissions=no name=mqttpublish owner=admin\
\_policy=\\\r\
\n ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon sou\
rce=\"#\\\r\
\n \\_Required packages: iot\\r\\\r\
\n \\n\\r\\\r\
\n \\n################################ Configuration ##################\
#######\\\r\
\n #######\\r\\\r\
\n \\n# Name of an existing MQTT broker that should be used for publish\
ing\\r\\\r\
\n \\n:local broker \\\"broker\\\"\\r\\\r\
\n \\n\\r\\\r\
\n \\n# MQTT topic where the message should be published\\r\\\r\
\n \\n:local topic \\\"my/test/topic\\\"\\r\\\r\
\n \\n\\r\\\r\
\n \\n#################################### System #####################\
#######\\\r\
\n #######\\r\\\r\
\n \\n:put (\\\"[*] Gathering system info...\\\")\\r\\\r\
\n \\n:local cpuLoad [/system resource get cpu-load]\\r\\\r\
\n \\n:local freeMemory [/system resource get free-memory]\\r\\\r\
\n \\n:local usedMemory ([/system resource get total-memory] - \\\$free\
Memory)\\r\\\r\
\n \\n:local rosVersion [/system package get value-name=version \\\\\\r\
\\\r\
\n \\n\\A0 \\A0 [/system package find where name ~ \\\"^routeros\\\"]]\
\\r\\\r\
\n \\n:local model [/system routerboard get value-name=model]\\r\\\r\
\n \\n:local serialNumber [/system routerboard get value-name=serial-nu\
mber]\\r\\\r\
\n \\n:local upTime [/system resource get uptime]\\r\\\r\
\n \\n\\r\\\r\
\n \\n#################################### MQTT #######################\
#######\\\r\
\n #######\\r\\\r\
\n \\n:local message \\\\\\r\\\r\
\n \\n\\A0 \\A0 \\\"{\\\\\\\"model\\\\\\\":\\\\\\\"\\\$model\\\\\\\",\\\
\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"sn\\\\\\\":\\\\\\\
\"\\\$serialNumber\\\\\\\",\\\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"ros\\\\\\\":\\\\\
\\\"\\\$rosVersion\\\\\\\",\\\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"cpu\\\\\\\":\\\$c\
puLoad,\\\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"umem\\\\\\\":\\\$\
usedMemory,\\\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"fmem\\\\\\\":\\\$\
freeMemory,\\\\\\r\\\r\
\n \\n\\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\A0 \\\\\\\"uptime\\\\\\\":\\\
\\\\\"\\\$upTime\\\\\\\"}\\\"\\r\\\r\
\n \\n\\r\\\r\
\n \\n:log info \\\"\\\$message\\\";\\r\\\r\
\n \\n:put (\\\"[*] Total message size: \\\$[:len \\\$message] bytes\\\
\")\\r\\\r\
\n \\n:put (\\\"[*] Sending message to MQTT broker...\\\")\\r\\\r\
\n \\n/iot mqtt publish broker=\\\$broker topic=\\\$topic message=\\\$m\
essage\\r\\\r\
\n \\n:put (\\\"[*] Done\\\")\""
add dont-require-permissions=no name=mqttpublish owner=admin policy=\
\_Required packages: iot\r\
\n\r\
\n################################ Configuration #########################\
#######\r\
\n# Name of an existing MQTT broker that should be used for publishing\r\
\n:local broker \"broker\"\r\
\n\r\
\n# MQTT topic where the message should be published\r\
\n:local topic \"my/test/topic\"\r\
\n\r\
\n#################################### System ############################\
#######\r\
\n:put (\"[*] Gathering system info...\")\r\
\n:local cpuLoad [/system resource get cpu-load]\r\
\n:local freeMemory [/system resource get free-memory]\r\
\n:local usedMemory ([/system resource get total-memory] - \$freeMemory)\r\
\n:local rosVersion [/system package get value-name=version \\\r\
\n\A0 \A0 [/system package find where name ~ \"^routeros\"]]\r\
\n:local model [/system routerboard get value-name=model]\r\
\n:local serialNumber [/system routerboard get value-name=serial-number]\r\
\n:local upTime [/system resource get uptime]\r\
\n\r\
\n#################################### MQTT ##############################\
#######\r\
\n:local message \\\r\
\n\A0 \A0 \"{\\\"model\\\":\\\"\$model\\\",\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"sn\\\":\\\"\$serialNumber\\\",\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"ros\\\":\\\"\$rosVersion\\\",\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"cpu\\\":\$cpuLoad,\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"umem\\\":\$usedMemory,\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"fmem\\\":\$freeMemory,\\\r\
\n\A0 \A0 \A0 \A0 \A0 \A0 \A0 \A0 \\\"uptime\\\":\\\"\$upTime\\\"}\"\r\
\n\r\
\n:log info \"\$message\";\r\
\n:put (\"[*] Total message size: \$[:len \$message] bytes\")\r\
\n:put (\"[*] Sending message to MQTT broker...\")\r\
\n/iot mqtt publish broker=\$broker topic=\$topic message=\$message\r\
\n:put (\"[*] Done\")"
add dont-require-permissions=no name="DHCP to DNS -- NEW" owner=admin policy=\
\_SPDX-License-Identifier: CC0-1.0\r\
\n\r\
\n:local domains [:toarray \"212.local\"]\r\
\n:local dnsttl \"100m\"\r\
\n:local magiccomment \"automatic-from-dhcp (magic comment)\"\r\
\n:local activehosts [:toarray \"\"]\r\
\n\r\
\n:foreach lease in [/ip dhcp-server lease find] do={\r\
\n :local hostname [/ip dhcp-server lease get value-name=host-name \$leas\
e]\r\
\n :local hostaddr [/ip dhcp-server lease get value-name=address \$lease]\
\r\
\n :local macaddr [/ip dhcp-server lease get value-name=mac-address \$lea\
se]\r\
\n\r\
\n :if ([:len \$hostname] > 0) do={\r\
\n\r\
\n :foreach domain in \$domains do={\r\
\n\r\
\n :local regdomain \"\$hostname.\$domain\"\r\
\n :set activehosts (\$activehosts, \$regdomain)\r\
\n\r\
\n :if ([:len [/ip dns static find where name=\$regdomain]] = 0) do={\
\r\
\n /ip dns static add name=\$regdomain address=\$hostaddr comment=\
\$magiccomment ttl=\$dnsttl\r\
\n } else={\r\
\n :if ([/ip dns static find where name=\$regdomain] = \$hostname) \
| ([/ip dhcp-server lease find where address=\$hostaddr] = \$macaddr) do=(\
\r\
\n\t\t :set regdomain=(\"\$hostname\", \"-1\") \r\
\n :/ip dns static add name=\$regdomain address=\$hostaddr commen\
t=\$magiccomment ttl=\$dnsttl\r\
\n } \r\
\n else={\r\
\n /ip dns static add name=\$regdomain address=\$hostaddr comment\
\n }\r\
\n\r\
\n\r\
\n :if ([:len [/ip dns static find where name=\$regdomain comment=\
\$magiccomment]] = 1) do={\r\
\n /ip dns static set address=\$hostaddr [/ip dns static find nam\
e=\$regdomain comment=\$magiccomment]\r\
\n \r\
\n }\r\
\n }\r\
\n }\r\
\n\r\
\n\r\
\n"
add dont-require-permissions=no name=rogue-dhcp owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
":log warning message=\"Rogue DHCP server detected!\""
add dont-require-permissions=no name=HassioLib_DeviceString owner=admin \
policy=read source="# Use\r\
\n# local DeviceString [parse [system/script/get \"HassioLib_DeviceString\
\" source]]\r\
\n# \$DeviceString\r\
\n#\r\
\nlocal ID\r\
\nlocal connections\r\
\nlocal hwversion\r\
\nlocal LowercaseHex [parse [system/script/get \"HassioLib_LowercaseHex\" \
source]]\r\
\n# Get serial\r\
\nif ([/system/resource/get board-name] != \"CHR\") do={\r\
\n set ID (\"\\\"\".[/system/routerboard get serial-number].\"\\\"\");#\
ID\r\
\n set \$hwversion [[:parse \"[system/routerboard/get revision]\"]]\r\
\n if ([len \$hwversion] >0) do={\r\
\n set \$hwversion (\"\\\"hw_version\\\":\\\"\".\$hwversion.\"\\\",\
\")\r\
\n }\r\
\n} else={\r\
\n set ID (\"\\\"\".[system/license/get system-id ].\"\\\"\")\r\
\n}\r\
\n\r\
\nlocal Name [/system/identity/get name]; #Name\r\
\nlocal Model [system/resource/get board-name]; #Mode\r\
\nlocal CSW [/system/resource/get version ]; #SW\r\
\nlocal Manu [/system/resource/get platform]; #Manufacturer\r\
\n\r\
\n\r\
\n# Get Ethernet MAC addresses\r\
\nforeach iface in=[interface/ethernet/find ] do={\r\
\n set \$connections (\$connections.\"[\\\"mac\\\",\\\"\".\\\r\
\n [\$LowercaseHex input=[/interface/ethernet/get \$iface mac-addre\
ss]].\\\r\
\n \"\\\"],\")\r\
\n}\r\
\n\r\
\n# Get Wi-Fi MAC addresses\r\
\nif ([len [system/package/find name=\"wifiwave2\"]] =0 ) do={\r\
\n local Action [parse \"local a [interface/wireless/get \\\$1 mac-addr\
ess];return \\\$a\"]\r\
\n foreach iface in=[[parse \"/interface/wireless/ find interface-type!\
=\\\"virtual\\\"\"]] do={\r\
\n [\$LowercaseHex input=[\$Action \$iface]].\\\r\
\n \"\\\"],\")\r\
\n }\r\
\n}\\\r\
\n# Get Wi-Fi Wave2 MAC Addresses\r\
\nelse={\r\
\n local Action [parse \"local a [/interface/wifiwave2/radio/get \\\$1 \
radio-mac];return \\\$a\"]\r\
\n foreach iface in=[[parse \"/interface/wifiwave2/radio/find\"]] do={\
\r\
\n \"\\\"],\")\r\
\n }\r\
\n}\r\
\nset \$connections [pick \$connections -1 ([len \$connections]-1)]; #Remo\
ve trailing comma\r\
\n\r\
\n# Find a reasonable link to WebFig if enabled.\r\
\nlocal urldomain\r\
\nlocal ipaddress\r\
\n\r\
\nforeach bridge in=[/interface/bridge/find] do={\r\
\n foreach AddressIndex in=[ip/address/find where interface=[/interface\
/bridge/get \$bridge name]] do={\r\
\n set ipaddress [/ip/address/get \$AddressIndex address]\r\
\n set \$ipaddress [:pick \$ipaddress 0 [:find \$ipaddress \"/\"]]\
\r\
\n foreach UrlIndex in=[/ip/dns/static/ find address=\$ipaddress nam\
e] do={\r\
\n set \$urldomain [/ip/dns/static/ get \$UrlIndex name ]\r\
\n }\r\
\n }\r\
\n}\r\
\nif ([len \$ipaddress]=0) do={\r\
\n foreach addr in=[/ip/address/find] do={\r\
\n local TempAddress [/ip/address/get \$addr address]\r\
\n set \$TempAddress [:pick \$TempAddress 0 [:find \$TempAddress \"\
/\"]]\r\
\n foreach UrlIndex in=[/ip/dns/static/find address=\$TempAddress] \
do={\r\
\n local TempUrlDomain [ip/dns/static/get \$UrlIndex name]\r\
\n if ([len \$TempUrlDomain]>0) do={set \$urldomain \$TempUrlDo\
main}\r\
\n }\r\
\n }\r\
\n}\r\
\nif ([len \$urldomain]>0) do={set \$ipaddress \$urldomain}\r\
\n\r\
\nlocal url\r\
\nif ([len \$ipaddress] >0) do={\r\
\n :if (! [/ip/service/get www-ssl disabled ]) \\\r\
\n do={:set \$url \",\\\"cu\\\":\\\"https://\$ipaddress/\\\"\"} \\\
\r\
\n else={if (! [/ip/service/get www disabled]) \\\r\
\n do={:set \$url \",\\\"cu\\\":\\\"http://\$ipaddress/\\\"\"}}\r\
\n}\r\
\n #-------------------------------------------------------\r\
\n #Build device string\r\
\n local dev \"\\\"dev\\\":{\\\r\
\n \\\"ids\\\":[\$ID],\\\r\
\n \\\"connections\\\":[\$connections],\\\r\
\n \\\"name\\\":\\\"\$Name\\\",\\\r\
\n \\\"mdl\\\":\\\"\$Model\\\",\$hwversion\\\r\
\n \\\"sw\\\":\\\"\$CSW\\\",\\\r\
\n \\\"mf\\\":\\\"\$Manu\\\"\$url}\"\r\
\n\r\
\n\r\
\nreturn \$dev"
add dont-require-permissions=no name=HassioLib_JsonEscape owner=admin policy=\
read source="# local JsonEscape [parse [system/script/get \"HassioLib_Json\
Escape\" source]]\
\n# \$JsonEscape input=\$a4\
\n#\
\n#global JsonEscape do= {\
\n #:global SearchReplace\
\n local SearchReplace [parse [system/script/get \"HassioLib_SearchRepl\
ace\" source]]\
\n :local escchars {\"\\\\\";\"\\\"\";\"/\";\"\\08\";\"\\0C\";\"\\0A\
\";\"\\0D\";\"\\08\"};\
\n :local escReplace {\"\\\\\\\\\";\"\\\\\\\"\";\"\\\\/\";\"\\\\b\";\"\
\\\\f\";\"\\\\n\";\"\\\\r\";\"\\\\t\"}\
\n foreach k,escchar in=\$escchars do={\
\n set \$input [\$SearchReplace input=\$input search=\$escchar repl\
ace=(\$escReplace->(\$k))]\
\n }\
\n return \$input\
\n\
\n#}"
add dont-require-permissions=no name=HassioLib_JsonPick owner=admin policy=\
\n# local JsonPick [parse [system/script/get \"HassioLib_JsonPick\" source\
]]\r\
\n# \$JsonPick input=\$a2 len=255\r\
\n#\r\
\n#global JsonPick do= {\r\
\n set \$input [pick \$input -1 \$len]\r\
\n local length [len \$input]\r\
\n if (([pick \$input (\$length-1)] = \"\\\\\") && ([pick \$input (\$le\
ngth-2)] != \"\\\\\")) do= {\r\
\n set \$input [:pick (\$input) -1 (\$length-1)]\r\
\n }\r\
\n return \$input\r\
\n#}"
add dont-require-permissions=no name=HassioLib_LowercaseHex owner=admin \
\n# local LowercaseHex [parse [system/script/get \"HassioLib_LowercaseHex\
\" source]]\r\
\n# \$LowercaseHex input=\$a4\r\
\n#\r\
\n#global LowercaseHex do= {\r\
\n #:global SearchReplace\r\
ace\" source]]\r\
\n :local escchars {\"A\";\"B\";\"C\";\"D\";\"E\";\"F\"}\r\
\n :local escReplace {\"a\";\"b\";\"c\";\"d\";\"e\";\"f\"}\r\
\n foreach k,escchar in=\$escchars do={\r\
ace=(\$escReplace->(\$k))]\r\
\n }\r\
\n\r\
\n#}"
add dont-require-permissions=no name=HassioLib_SearchReplace owner=admin \
\n# local SearchReplace [parse [system/script/get \"HassioLib_SearchReplac\
e\" source]]\r\
\n# \$SearchReplace input=\"abc\" search=\"a\" replace=\"b\"\r\
\n#\r\
\n#global SearchReplace do= {\r\
\n :local out \"\"\r\
\n :local index 0\r\
\n :local length [:len \$input]\r\
\n :local findex\r\
\n\r\
\n set \$findex [find \$input \$search (\$index-1) ]\r\
\n while ([len \$findex] != \"0\") do={\r\
\n set \$out (\$out.[pick \$input \$index \$findex ].\$replace)\r\
\n set \$index (\$findex+[len \$search])\r\
\n }\r\
\n set \$out (\$out.[pick \$input (\$index) \$length ])\r\
\n :return \$out\r\
\n#}\r\
\n"
add dont-require-permissions=no name="Hassio Firmware Entity Publish" owner=\
admin policy=read,test source="if ([len [system/package/find name=\"iot\"]\
]=0) do={ ; # If IOT packages is not installed\r\
\n log/error message=\"HassioMQTT: IOT package not installed.\"\r\
\n} else={\r\
\n if ([len [iot/mqtt/brokers/find name=\"Home Assistant\"]]=0) do={ ;#\
\_If Home assistant broker does not exist\r\
\n log/error message=\"HassioMQTT: Broker does not exist.\"\r\
\n } else={\r\
\n while (![/iot/mqtt/brokers/get [/iot/mqtt/brokers/find name=\"Ho\
me Assistant\"] connected ]) do={ ;# If Home assistant broker is not conne\
cted\r\
\n log/info message=\"HassioMQTT: Broker not connected reattemp\
ting connection...\"\r\
\n delay 1m; # Wait and attempt reconnect\r\
\n iot/mqtt/connect broker=\"Home Assistant\"\r\
\n }\r\
\n\r\
\n\r\
\n local discoverypath \"homeassistant/\"\r\
\n local domainpath \"update/\"\r\
\n\r\
\n #Get variables to build device string\r\
\n\r\
\n local ID\r\
\n if ([/system/resource/get board-name] != \"CHR\") do={\r\
\n set ID [/system/routerboard get serial-number];#ID\r\
\n } else={\r\
\n set ID [system/license/get system-id ]\r\
\n }\r\
\n local DeviceString [parse [system/script/get \"HassioLib_DeviceS\
tring\" source]]\r\
\n local dev [\$DeviceString]\r\
\n local buildconfig do= {\r\
\n\r\
\n #build config for Hassio\r\
\n local config \"{\\\"~\\\":\\\"\$discoverypath\$domainpath\$I\
D/\$name\\\",\\\r\
\n \\\"name\\\":\\\"\$name\\\",\\\r\
\n \\\"stat_t\\\":\\\"~/state\\\",\\\r\
\n \\\"uniq_id\\\":\\\"\$ID_\$name\\\",\\\r\
\n \\\"obj_id\\\":\\\"\$ID_\$name\\\",\\\r\
\n \$dev\\\r\
\n }\"\r\
\n /iot/mqtt/publish broker=\"Home Assistant\" message=\$config\
\_topic=\"\$discoverypath\$domainpath\$ID/\$name/config\" retain=yes \
\_ \r\
\n }\r\
\n #Handle routerboard firmware for non CHR\r\
\n \$buildconfig name=\"RouterBOARD\" ID=\$ID discoverypath=\$d\
iscoverypath domainpath=\$domainpath dev=\$dev\r\
\n }\r\
\n\r\
\n #Handle RouterOS\r\
\n \$buildconfig name=\"RouterOS\" ID=\$ID discoverypath=\$discover\
\n\r\
\n #Handle LTE interfaces\r\
\n :foreach iface in=[/interface/lte/ find] do={\r\
\n local ifacename [/interface/lte get \$iface name]\r\
\n\r\
\n #Get manufacturer and model for LTE interface\r\
\n local lte [ [/interface/lte/monitor [/interface/lte get \$iface \
name] once as-value] manufacturer]\r\
\n if (\$lte->\"manufacturer\"=\"\\\"MikroTik\\\"\") do={\r\
\n {\r\
\n #build config for LTE\r\
\n local modemname [:pick (\$lte->\"model\")\\\r\
\n ([:find (\$lte->\"model\") \"\\\"\" -1] +1)\\\r\
\n [:find (\$lte->\"model\") \"\\\"\" [:find (\$lte->\"\
model\") \"\\\"\" -1]]]\r\
\n \$buildconfig name=\$modemname ID=\$ID discoverypath=\$d\
\n }\r\
\n }\r\
\n }\r\
\n }\r\
\n}"
add dont-require-permissions=no name="Hassio Firmware State Publish" owner=\
admin policy=read,write,policy,test source="if ([len [system/package/find \
name=\"iot\"]]=0) do={ ; # If IOT packages is not installed\r\
\n} else={\r\
\n } else={\r\
\n local Ctr 0\r\
\n while ((![/iot/mqtt/brokers/get [/iot/mqtt/brokers/find name=\"H\
ome Assistant\"] connected ])&&(Ctr<12)) do={ ;# If Home assistant broker \
is not connected\r\
\n set \$Ctr (\$Ctr+1)\r\
\n }\r\
\n :global HassioReleaseNote\r\
\n #ID\r\
\n local ID\r\
\n } else={\r\
\n }\r\
\n\r\
\n local poststate do= {\r\
\n if ((typeof \$url)!=nil) do={\r\
\n set \$url \",\\\"release_url\\\":\\\"\$url\\\"\"\r\
\n }\r\
\n\r\
\n if ((typeof \$note)!=nil) do={\r\
\n set \$note \",\\\"release_summary\\\":\\\"\$note\\\"\"\r\
\n }\r\
\n\r\
\n local state \"{\\\"installed_version\\\":\\\"\$cur\\\",\\\r\
\n \\\"latest_version\\\":\\\"\$new\\\"\$url\$note}\"\r\
\n /iot/mqtt/publish broker=\"Home Assistant\" message=\$state \
topic=\"\$discoverypath\$domainpath\$ID/\$name/state\" retain=yes\r\
\n }\r\
\n #Get routerboard firmware\r\
\n local Act [parse \"/system/routerboard/get current-firmware\
\"]\r\
\n local cur [\$Act]\r\
\n local Act [parse \"/system/routerboard/get upgrade-firmware\
\"]\r\
\n local new [\$Act]\r\
\n #post Routerboard firmware\r\
\n \$poststate name=\"RouterBOARD\" cur=\$cur new=\$new ID=\$ID\
\_discoverypath=\$discoverypath domainpath=\$domainpath\r\
\n }\r\
\n\r\
\n #Get system software\r\
\n local versions [/system/package/update/check-for-updates as-valu\
e ]\r\
\n\r\
\n local cur (\$versions->\"installed-version\")\r\
\n local new (\$versions->\"latest-version\")\r\
\n\r\
\n #Get release note:\r\
\n if ((\$HassioReleaseNote->\"version\")!=new) do={\r\
\n #:global HassioReleaseNote\r\
\n\r\
\n :set (\$HassioReleaseNote->\"note\") ([/tool/fetch \"http://\
upgrade.mikrotik.com/routeros/\$new/CHANGELOG\" output=user as-value]->\"d\
ata\")\r\
\n :set (\$HassioReleaseNote->\"note\") [:pick (\$HassioRelease\
Note->\"note\") -1 255]\r\
\n\r\
\n #Text must be escaped before posting as JSON!\r\
\n local JsonEscape [parse [system/script/get \"HassioLib_JsonE\
scape\" source]]\r\
\n set (\$HassioReleaseNote->\"note\") [\$JsonEscape input=(\$H\
assioReleaseNote->\"note\")]\r\
\n\r\
\n local JsonPick [parse [system/script/get \"HassioLib_JsonPic\
k\" source]]\r\
\n set (\$HassioReleaseNote->\"note\") [\$JsonPick input=(\$Has\
sioReleaseNote->\"note\") len=255]\r\
\n :set (\$HassioReleaseNote->\"version\") \$new\r\
\n /log/debug message=\"HassioMQTT: Release note fetched.\"\r\
\n } else={/log/debug message=\"HassioMQTT: Release note already ca\
ched, not fetched.\"}\r\
\n\r\
\n local urls {development=\"https://mikrotik.com/download/changelo\
gs/development-release-tree\";\\\r\
\n long-term=\"https://mikrotik.com/download/changelogs/long-te\
rm-release-tree\";\\\r\
\n stable=\"https://mikrotik.com/download/changelogs/stable-rel\
ease-tree\";\\\r\
\n testing=\"https://mikrotik.com/download/changelogs/testing-r\
elease-tree\"}\r\
\n set urls (\$urls->[system/package/update/get channel ])\r\
\n\r\
\n \$poststate name=\"RouterOS\" cur=\$cur new=\$new url=\$urls not\
e=(\$HassioReleaseNote->\"note\") ID=\$ID discoverypath=\$discoverypath do\
\n\r\
\n\r\
\n {\r\
\n\r\
\n #Get firmware version for LTE interface\r\
\n local Firmware [/interface/lte firmware-upgrade [/interf\
ace/lte get \$iface name] once as-value ]\r\
\n local cur (\$Firmware->\"installed\")\r\
\n local new (\$Firmware->\"latest\")\r\
\n\r\
\n \$poststate name=\$modemname cur=\$cur new=\$new ID=\$ID\
\n }\r\
\n }\r\
\n }\r\
\n }\r\
\n}"
add dont-require-permissions=no name=HassioSensorHealthEntityPublish owner=\
\n} else={\r\
\n } else={\r\
cted\r\
\n }\r\
\n\r\
\n local domainpath \"sensor/\"\r\
\n\r\
\n\r\
\n local ID [/system/routerboard get serial-number];#ID\r\
\n\r\
tring\" source]]\r\
\n local SearchReplace [parse [system/script/get \"HassioLib_Se\
archReplace\" source]]\r\
\n local jsonname (\"x\".[\$SearchReplace input=\$name search=\
\"-\" replace=\"_\"])\r\
\n\r\
\n local config \"{\\\"name\\\":\\\"\$name\\\",\\\r\
\n \\\"stat_t\\\":\\\"\$discoverypath\$domainpath\$ID/state\
\\\",\\\r\
\n \\\"suggested_display_precision\\\": 1,\\\r\
\n \\\"unit_of_measurement\\\": \\\"\$unit\\\",\\\r\
\n \\\"value_template\\\": \\\"{{ value_json.\$jsonname }}\
\\\",\\\r\
\n \\\"expire_after\\\":70,\\\r\
\n \$dev\\\r\
\n }\"\r\
\_ \r\
\n }\r\
\n foreach sensor in=[/system/health/find] do={\r\
\n local name [/system/health/get \$sensor name];#name\r\
\n local unit [/system/health/get \$sensor type];#unit\r\
\n if (\$unit=\"C\") do={set \$unit \"\\C2\\B0\\43\"}\r\
\n \$buildconfig name=\$name unit=\$unit ID=\$ID discoverypath=\
\$discoverypath domainpath=\$domainpath dev=\$dev\r\
\n }\r\
\n }\r\
\n}"
add dont-require-permissions=no name=HassioSensorHealthStatePublish owner=\
admin policy=read,write,test source="if ([len [system/package/find name=\"\
\n} else={\r\
\n } else={\r\
\n\r\
\n #ID\r\
\n local ID [/system/routerboard get serial-number] \r\
\n\r\
\n local string \"{\"\r\
\n local SearchReplace [parse [system/script/get \"HassioLib_Search\
\n set \$string ((\$string).(\"\\\"\").\\\r\
\n (\"x\").([\$SearchReplace input=[/system/health/get \$se\
nsor name] search=\"-\" replace=\"_\"]).(\"\\\":\").\\\r\
\n ([/system/health/get \$sensor value]).(\",\"))\r\
\n }\r\
\n set \$string ([pick \$string -1 ([len \$string ]-1)].\"}\")\r\
\n \r\
\n /iot/mqtt/publish broker=\"Home Assistant\" message=\$string top\
ic=\"\$discoverypath\$domainpath\$ID/state\" retain=no \r\
\n }\r\
\n}"
add dont-require-permissions=no name=HassioSensorPoeEntityPublish owner=admin \
policy=read,test source="if ([len [system/package/find name=\"iot\"]]=0) d\
\n} else={\
\n } else={\
cted\
\n }\
\n\
\n\
\n\
tring\" source]]\
\n\
\n local config (\"{\\\"name\\\":\\\"\$name\".\" POE\".\"\\\",\
\$NamePostfix\\\",\\\
\n \\\"uniq_id\\\":\\\"\$ID_\$name\$NamePostfix\\\",\\\
\n \\\"obj_id\\\":\\\"\$ID_\$name\$NamePostfix\\\",\\\
\n \\\"value_template\\\": \\\"{{ value_json.\$jsonname | i\
s_defined}}\\\",\\\
\n \$dev\\\
\n }\")\
\_topic=(\"\$discoverypath\$domainpath\$ID/\$name\$NamePostfix/config\") r\
etain=yes \
\n }\
\n foreach sensor in=[/interface/ethernet/poe/find] do={\
\n local name [/interface/ethernet/poe/get \$sensor name];#name\
\n \$buildconfig name=(\$name) unit=W NamePostfix=\"_poe\" ID=\
\$ID discoverypath=\$discoverypath domainpath=\$domainpath dev=\$dev\
\n }\
\n }\
\n}"
add dont-require-permissions=no name=HassioSensorPoeStatePublish owner=admin \
policy=read,test source="local discoverypath \"homeassistant/\"\
\nlocal domainpath \"sensor/\"\
\nlocal ID [/system/routerboard get serial-number] \
\n\
\nlocal Out \"{\"\
\n\
\nforeach iface in=[/interface/ethernet/poe/ find] do={\
\n local InterfaceName [/interface/ethernet/poe/get \$iface name]\
\n local InterfaceValue [interface/ethernet/poe/monitor \$iface once as\
-value ]\
\n if ([:len (\$InterfaceValue->\"poe-out-current\")]=0) do={set (\$Int\
erfaceValue->\"poe-out-current\") 0}\
\n set \$Out (\$Out.\"\\\"x\$InterfaceName\\\":\".\\\
\n [([:tonum [(\$InterfaceValue->\"poe-out-current\")]]/10) ].\\\
\n \".\".\\\
\n ([:tonum [(\$InterfaceValue->\"poe-out-current\")]]%10).\\\
\n \",\")\
\n}\
\nset \$Out ([pick \$Out -1 ([len \$Out]-1)].\"}\")\
\n/iot/mqtt/publish broker=\"Home Assistant\" message=\$Out topic=\"\$disc\
overypath\$domainpath\$ID/state_poe\" retain=no"
add dont-require-permissions=no name=DHCP-LEASE-TEST2 owner=admin policy=\
system\r\
\n\r\
\n\r\
\n:foreach i in=[/ip dhcp-server lease find] do={\r\
\n:put ([get \$i comment].\",\".[get \$i address].\",\".[get \$i mac-addre\
ss].\",\".[get \$i host-name])\r\
\n\r\
\nfile=\"test1.txt\"\r\
\n}"
add dont-require-permissions=no name=dhcpleasesftp owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\r\
\n/file remove [find where name=temp3.txt]\r\
\n\r\
\n/system\r\
\n\r\
\n:local identitydate \"\$[identity get name]\"\r\
\n\r\
\n:local stringexec \"/ip dhcp-server lease; :foreach i in=[find] do={ :pu\
t ([get \\\$i address].\\\",\\\".[get \\\$i comment].\\\",\\\",[get \\\$i \
mac-address].\\\",\\\".[get \\\$i host-name] ) }\"\r\
\n\r\
\n\r\
\n:execute \$stringexec file=temp3\r\
\n\r\
\n:delay 60\r\
\n\r\
\n/tool fetch address=192.168.2.22 port=21 user=mikrotik password=PASSWORD\
\_src-path=temp3.txt mode=ftp dst-path=\"/mikrotik-backups/\$identitydate-\
leases.txt\" upload=yes ascii=no\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n"
add dont-require-permissions=no name=script1 owner=admin policy=\
\r\
\n/file remove [find where name=temp2.txt]\r\
\n\r\
\n/system\r\
\n\r\
\n:local identitydate \"\$[identity get name]_\$[clock get date]\"\r\
\n\r\
mac-address].\\\",\\\".[get\r\
\n \\\$i host-name] ) }\"\r\
\n\r\
\n\r\
\n:execute \$stringexec file=temp2.txt\r\
\n\r\
er=mikrotik password=PASSWORD src-path=\"temp2.txt\" dst-path=\"/mikrotik-\
backups/\$identitydate-leases.txt\"\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n\r\
\n"
add dont-require-permissions=yes name=WG-iface-restart-log-lasthandshake \
e]\r\
\n\r\
\_\"2m\"])) do={\r\
\n\r\
\n :if ((\$LastHandshake > [:totime \"2m\"])) do={\r\
\n\r\
\n# :local lasthandshaketime [:totime]\r\
\r\
\n\r\
\n :log info \"WG-iface-restart-log-lasthandshake script found WG peer wi\
th last handshake greater than 2 minutes: \$endpoint \$LastHandshake\"\r\
\n \r\
\n# /interface/wireguard/peers/set \$i endpoint-address=[/interface/wir\
eguard/peers/get \$i endpoint-address]\r\
\n\r\
\n }\r\
\n}\r\
\n\r\
\n"
/system ups
add name=ups1 port=usbhid1
/system watchdog
set watchdog-timer=no
/tool bandwidth-server
set authenticate=no
/tool e-mail
set from=email@email.com password=PASSWORD port=587 server=\
smtp.gmail.com tls=starttls user=email@email.com
/tool graphing interface
add
add
/tool graphing queue
add
add
/tool graphing resource
add
add
/tool mac-server
set allowed-interface-list=MANAGE
/tool mac-server mac-winbox
/tool netwatch
add comment=212 disabled=yes down-script="" host=10.10.100.1 http-codes="" \
test-script="" type=simple up-script=""
add comment=371 disabled=yes down-script="" host=10.10.100.40 http-codes="" \
add comment=355 disabled=yes down-script="" host=10.10.100.3 http-codes="" \
add comment=255 disabled=yes down-script="" host=10.10.100.4 http-codes="" \
add disabled=yes down-script="" host=10.10.100.5 http-codes="" test-script="" \
add comment=LAPTOP disabled=yes down-script="" host=10.10.100.8 http-codes="" \
add comment=iPhone disabled=yes down-script="" host=10.10.100.9 http-codes="" \
add comment=212 disabled=yes down-script="" host=192.168.2.2 http-codes="" \
add comment=371 disabled=yes down-script="" host=192.168.88.1 http-codes="" \
interval=5s test-script="" type=simple up-script=""
add comment=629 disabled=yes down-script="" host=192.168.20.1 http-codes="" \
add comment=76 disabled=yes down-script="" host=192.168.30.2 http-codes="" \
add comment=355 disabled=yes down-script="" host=192.168.0.11 http-codes="" \
add comment=255 disabled=yes down-script="" host=192.168.1.2 http-codes="" \
add comment=LAPTOP disabled=yes down-script="" host=10.10.100.201 http-codes=\
"" test-script="" type=simple up-script=""
add disabled=yes down-script=":local thisBox [/system identity get name];\r\
\n\r\
\n:tool e-mail send to=email@email.com subject=\"\$thisBox DOWN\" b\
ody=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \"\
\$thisBox DOWN to 8.8.8.8\" )" host=8.8.8.8 http-codes="" interval=5s \
test-script="" type=simple up-script=":local thisBox [/system identity get\
\_name];\r\
\n\r\
\n:tool e-mail send to=email@email.com subject=\"\$thisBox UP\" bod\
y=( [ :system clock get date ] . \" \" . [ :system clock get time ] . \"\$\
thisBox UP to 8.8.8.8\" )"
add disabled=no down-script=":local thisBox [/system identity get name];\r\
\n\r\
\$thisBox DOWN to 96.250.224.1)" host=96.250.224.1 http-codes="" \
interval=30m test-script="" type=simple up-script=":local thisBox [/system\
\_identity get name];\r\
\n\r\
\n:tool e-mail send to=email@email.com subject=\"\$thisBox UP body=\
( [ :system clock get date ] . \" \" . [ :system clock get time ] . \"\$th\
isBox UP to 96.250.224.1\" )"
/tool romon
set enabled=yes
/tool sniffer
set file-limit=10000KiB filter-mac-address=\
18:FD:74:38:81:2E/FF:FF:FF:FF:FF:FF memory-limit=10000KiB \
streaming-server=192.168.2.22
/tool traffic-monitor
add disabled=yes interface=ether1 name=tmon1
add disabled=yes interface=ether3 name=tmon2 traffic=received trigger=always
