I’m using FreeRadius running on a Linux Fedora box, sitting in my office in one town, handling Authentication and Accounting for tree networks in three other towns.
http://www.freeradius.org
The documentation tells you just about everything you need to know about it,
but I’ll be happy to consult if you need more help with that one.
RADIUS can be set up to query a SQL database for user info and group parameters,
including bandwidth-limitations and some-such, throughput monitoring…
And you can manage/view the SQL database with some simple PHP scripts.
You can use this to add, remove, disable users, monitor their throughput,
change their bandwidth-limits…
Then, Mikrotik can be set up to query your Radius for Auths, and dump all it’s accounting info on it too. Radius will neatly place it in the SQL database, ready for you to view or process.
I can tell you that RADIUS with SQL works great, but building PHP front-end stuff to administrate it can be very tricky. I’ve managed with spitballs and sticky-tape.
I’m not, however, discrediting User Manager as an option, which I quite frankly know nothing about. But yell if you need help on RADIUS.
User Manager is very good tool, as with installed User Manager package makes your router as advanced management server for HotSpot, PPP, wireless and DHCP clients. Just one command required to enable WEB interface of the User Manager, that is very user-friendly and intuitive, you do need to set a “bunch” of console commands to get it work.
More information about User Manager, http://wiki.mikrotik.com/wiki/User_Manager
It is not very arguable response, you may post here and at the "Feature Request’ topic for the features, that are required, but they are not present at User-Manager.
in my opinion freeradius with radiusmanager is the best solution ATM. Usermanager just doesn’t have the features to support a in my situation a wisp or hotspot with having the account provisoned at the signup process as in different prices for diff speeds and have it auto populate to the customer. Most ISPs and hotspots utilize this feature to control per user bandwidth. I and others have requested this feature and told there was no plan to add the feature. On the plus if you don’t need persignup bandwith management like you don’t care if all users auto get like 1.5/1.5 and then you change it after signup then usermanager word great. Can’t go wrong with a all in one point and click solution
In case your post is about total amount of traffic downloaded/+uploaded at signup stage (sell specific amount of bandwidth to the customer), such feature is planned at the future.
yes what we are lookin for is to add packages at signup that are not for total allowed download , but differnet speeed packages like building ques into the packages , id want the user to be able to choose what what speed they want upon signup instead of putting it on my page and then having to change it once i get the email, this is currently not possible with usermanger but is possible with radiusmanager. I was told this wasnt going to be added in the future either, which is really going to limit the use or usermanager forcing all customers to have the same speed and default que, hope you guys change your mind on this , until then radiusmanager fits my needs better than the usermanager. Im sure alot of others would like this feature as well
The abililty to tie ques to plans, so lets say the 19.99 plan for 30 days gets the user 1.5
where as the 39.99 plan would give them the 6.0 plan for 30 days , and have it auto create the ques on sign-up.
This would darn near complete the usermanager package in my opinion
there are some very serious limitations in RouterOS that don’t allow us to make all that is needed for a complete billing system. We will try to overcome those limitations and then a lot of new features will be possible.
Hello frens,
as far as i used routerOS just made bw management and routing system only since 2 years ago, and about billing i made by myself for communication user to my central server:
and this screen shot my billing system. this's nice for myself and for dynamic user i used userman [Centralized AAA] to make control hotspot, pptp, and pppoe user
Hello balimore this your billing system is it some thing you want to share ? if u want to please i will appreciate if you could mail it to me at onowojemma@yahoo.com
thanks
I’ve used Free Radius but with the need of dynamic packages for the customers; I started using 24Online as AAA with Mikrotik as Access Gateway. That worked out to be much better as Billing & Bandwidth Mgmt Paltform. Ease of manageability and handling.
