Is there an MT device that can reside outdoors and that I can stick a Verizon (United States) sim card in provide routing/internet-access to an outdoor camera?
Thanks!
Thanks!
The wAPac (or SXT and LHG) with LTE6 modem likely work, unless the location really only has band 13 (which is possible). You can see what cellmapper.com says about the bands and verify they overlap with LTE6.
As noted in other threads about Verizon, they will not let you activate a new SIM card using any Mikrotik LTE devices (as none are certified in their “Open” Developers program), so you’d need a SIM card from some other device too.
A longer explanation can be found here: http://forum.mikrotik.com/t/no-lte-connection-with-sxt-nor-atl-but-within-range-of-tower-bands-13-66/169189/1
Thanks very much!
Now to design a solar system to power a wAPac and camera…
It is 1 year later and I wonder if anything has changed?
Specifically, is there an LTE/4G device that will work in the US without jumping through hoops?
Thanks.
