I thought I’d put my input on this question as I now own one of these routers!
My business has been a Cisco house for almost 10 years, and I’m now slowly converting my networking infrastructure to MikroTik devices, starting with replacing the core router for my server room with this new router.
I’ve tested this router in several of my servers and a few desktops with varying results.
RESULTS
IBM x3650 M4: WORKS BUT I DO NOT RECOMMEND - rebooting the PCIe router causes the server to reboot too. Also other strange behavior- AND no option for boot delay.
QCT QuantaPlex Node: WORKS WITH LIMITATIONS - These QCT Nodes have no built in Ethernet ports, so if you use up the PCIe slot for the MikroTik you loose your PCIe option for ethernet/SFP ports. (In my case the passthrough won’t work on my nodes as they run Windows Hyper-V and Windows doesn’t recognize them) HOWEVER these nodes have optional Mezz network cards you could use instead - other issue, no option for boot delay.
Supermicro 6017/6027: WORKS without passthrough - sure, do this if you want. The older Supermicro servers don’t have a boot delay option either, so mileage may vary for passthrough.
Asus Z270 PC board: works, but no boot delay option.
At the end of the day I’m going to pick any server that’s not an IBM x3650 M4 with an empty PCIe 8x or better slot and use it. The majority of my servers don’t have a boot delay option so PCIe passthrough is out of the question entirely, however that was not a selling point for me and my systems all have an abundance of connectivity options so it’s not a deal breaker either. The simple fact I can gain a single RU by ditching my Cisco router and putting a router into a PCIe slot that also supports 25Gb speeds is what makes this product so appealing to me.
The only downside when testing in a desktop was noise, after a few hours the fan on the MikroTik would gradually ramp higher and higher until it was a maximum speed, even with the router shutdown. For me it wont be a problem as this will be installed in a server, in a server room, where noise is just a fact, and I probably won’t even hear it among the servers.
CCR 2004 PCIe 10/10 would recommend
