who came to what sites (solution)
Sorry my language, this is google translate. Often leaders pronounced something like “I want to know who is on what sites and when to sign up.”I tried to find any ready solution to this problem on the internet, but found nothing. I had to do everything myself. The solution I suggest to anyone who is looking like. Simple, but it works. Attach failed, here is the link - take: http://pvv.uk-tlt.ru/viewlogs-free.zip
Errors, remarks, suggestionswelcome . Guide inside zip.
Isn’t it something like spam or a way how to get a virus or something like that?
The link is suspicious to me, too. :wink: It is a link to a file.
Sent from my Redmi Note 2 using Tapatalk
I have downloaded zip file, unpacked … living^H^H^H^H^Hmoderating on the edge :slight_smile: … no signs of virus … G-Data says nothing … then accepted.
Great! Can You share Your first thoughts about it? :slight_smile:
Ok, I downloaded it too. It seems to be clean. I will test it later. Many thanks!
Just checked for safety, not tested.
This not spam and not a virus. This is really program and her really work. My site: http://pvv.uk-tlt.ru
(sorry, me write on english first time in my life :slight_smile:
Заметно…
Пардон, не сдержался. :slight_smile:
А что, здесь все полностью русскоговорящие?
Guys, not many people will understand You. Please write english, no matter how bad it is.
Best Regards.
That was a bit of sarcasm from my side. Nothing technical (complete off-topic). Sorry. :slight_smile:
Sorry, will not happen again
