why do i get an error here?
:set hostname $[ip dhcp-server lease get [find address=“192.168.1.$i”] host-name ];
I get an error here (red bold)
The script works if i remove the line completely (so there are no other errors and looping works fine. I just wanted to add hostnames in the report
remove $ that is before [
Same error
The line:
:set hname [ip dhcp-server lease get [ find address=“192.168.1.$i” ] host-name ] ;
Error:
bad command name ip (line 13 column 25)
(cursor location indicator in the script editor would be very useful right about now :open_mouth: )
BTW. version 5.1
:set hname [/ip dhcp-server lease get [find address=“192.168.1.$i”] host-name ];
tryed it before …
:set hname [/ip dhcp-server lease get [find address=“192.168.1.$i”] host-name] ;
interrupted
no such item
so i changed it to:
:if ([/ip dhcp-server lease get [find address=“192.168.1.$i”] host-name] = nil) do={ :set hname “none” } else={ :set hname [/ip dhcp-server lease get [find address=“192.168.1.$i”] host-name] }
and still the same error (no such item)
if “find” returns more than one item then you have to use :foreach to go through array of returned items.
How is the variable $i assigned a value? Can you post the rest of the code in the loop?
ADD: I tried this and got no errors:
local hname;
:for i from=1 to=10 do={
    :set hname [/ip dhcp-server lease get [/ip dhcp-server lease find address="192.168.1.$i"] host-name ] ;
Here is the code:
      :global traf;
       :global megsu "0";
       :global megsd "0";
       :global resulter "";
       :local logmsg;
       :local hname "";
       /queue tree
           :for i from=1 to=9 do={
                   :set logmsg "";
                   :set megsd "0";
                   :set megsu "0";
                   :if ([/ip dhcp-server lease get [find address="192.168.1.$i"] host-name] = nil) do={ :set hname "none" } else={ :set hname [/ip dhcp-server lease get [find address="192.168.1.$i"] host-name] }
                   :set hname [/ip dhcp-server lease get [find address="192.168.1.$i"] host-name] ;
                   :if ([/queue tree find name="192.168.1.00$i_D"]!="") do={:set traf [get [find name="192.168.1.00$i_D"] bytes]; :set megsd ($traf / 1000);}
                   :if ([/queue tree find name="192.168.1.00$i_U"]!="") do={:set traf [get [find name="192.168.1.00$i_U"] bytes]; :set megsu ($traf / 1000);}
                   :if ($megsd > 0) do={
                       :if ($megsd > 1000) do={ :set megsd ($megsd / 1000); :set megsd "$megsd Mb" } else={ :set megsd "$megsd Kb"}
                       :set logmsg ("192.168.1.00$i_D: $megsd");
                       :set resulter ("$resulter \n User: $hname 192.168.1.00$i Download: $megsd")
                   :if ($megsu > 0) do={
                       :if ($megsu > 1000) do={ :set megsu ($megsu / 1000); :set megsu "$megsu Mb" } else={ :set megsu "$megsu Kb"}
                       :if ($logmsg!="") do={:set resulter ("$resulter Upload: $megsu")} else={:set resulter ("$resulter \n User: $hname 192.168.1.00$i Upload: $megsu")}
                       :if ($logmsg!="") do={ :set logmsg ("$logmsg 192.168.1.00$i_U: $megsu"); } else={ :set logmsg ("192.168.1.00$i_U: $megsu"); }
                   :if ($logmsg!="") do={ :log info ($logmsg) }
All queues exist (they are static) but not all IP’s are assigned via DHCP (wich is the mikrotik itself), some are static (and i figure, i’ll get an empty string for those)
You are not including the full path on the “find” requests.
Don’t use [find address=“192.168.1.$i”]
Use [/ip dhcp-server lease find address=“192.168.1.$i”]
Same applies to the rest of the “find” requests in the code.
full path is not required there, find will use current path.
For example in
current path is set to “/ip dhcp-server lease” and find will also use it.
Regarding tplecko problem:
Does entries with addresses “192.168.1.1-192.168.1.9” exist in dhcp lease menu?
Not all IP addresses will exist. 1-5 are static, 6-9 are dynamic. currently 1,2,5,7,8 and 9 exist (but in dhcp lease list, i can see 1,2 and 5 as busy and with no hostname)
then you have an answer
if [find address=“192.168.1.$i”] is unable to find anything then getis trying to get hostname from nothingand you get “no such item”
Try
:if (/ip dhcp-server lease find address=“192.168.1.$i” != “”) do={
As i submited the post, i realized just that!
But i have just upgraded my ubuntu to 11.04 and crossover stopped working so testing this will wait until i fix my current problem!
Thanks for helping!
If anyone is interested:
Queue tree is quite simple. For sorting purposes, names of items are IP addresses ending with 3 digit number (meaning 192.168.1.1 rule has name 192.168.1.001)
This results in 3 for-loops since i check the name of queue items (i have an idea to fix this but am lazy to do it)
I have one for the complete /24 range for upload and for download.
This script reports bandwidth usage per IP address. It reports the hostname too if the DHCP is on the same device.
Unfortunatley i don’tt know how and if mikrotik can get hostnames from IP addresses any other way. (note for another feature request)
Here is the script:
:log error "Queue Stats Start"
:local traf;
:local megsu "0";
:local megsd "0";
:local resulter "";
:local logmsg;
:local hname "";
/queue tree
        :set logmsg "";
        :if ( [/ip dhcp-server lease find address="192.168.1.$i"] != "" ) do={
            :if ( [/ip dhcp-server lease get [find address="192.168.1.$i"] host-name] != "") do={
            } else={
                :set hname "unknown"
        } else={
            :set hname "n/a"
            :set logmsg ("192.168.1.$i Down: $megsd");
            :set resulter ("$resulter \n IP: 192.168.1.00$i Host: $hname Down: $megsd")
                :set resulter ("$resulter Up: $megsu")
                :set logmsg ("$logmsg Up: $megsu")
            } else={
                :set resulter ("$resulter \n Ip: 192.168.1.00$i Host: $hname Up: $megsu")
                :set logmsg ("192.168.1.$i Up: $megsu");
    :for i from=10 to=99 do={
        :set logmsg "";
            } else={
        } else={
            :set hname "n/a"
        :if ([/queue tree find name="192.168.1.0$i_D"]!="") do={:set traf [get [find name="192.168.1.0$i_D"] bytes]; :set megsd ($traf / 1000);}
        :if ([/queue tree find name="192.168.1.0$i_U"]!="") do={:set traf [get [find name="192.168.1.0$i_U"] bytes]; :set megsu ($traf / 1000);}
            :set resulter ("$resulter \n IP: 192.168.1.0$i Host: $hname Down: $megsd")
            } else={
                :set resulter ("$resulter \n Ip: 192.168.1.0$i Host: $hname Up: $megsu")
    :for i from=100 to=254 do={
        :set logmsg "";
            } else={
        } else={
            :set hname "n/a"
        :if ([/queue tree find name="192.168.1.$i_D"]!="") do={:set traf [get [find name="192.168.1.$i_D"] bytes]; :set megsd ($traf / 1000);}
        :if ([/queue tree find name="192.168.1.$i_U"]!="") do={:set traf [get [find name="192.168.1.$i_U"] bytes]; :set megsu ($traf / 1000);}
            :set resulter ("$resulter \n IP: 192.168.1.$i Host: $hname Down: $megsd")
            } else={
                :set resulter ("$resulter \n Ip: 192.168.1.$i Host: $hname Up: $megsu")
/tool e-mail send body="$[/system identity get name] queue stats report on: $[/system clock get date]@$[/system clock get time]\n\n$resulter" subject="Queue stats" to="me@myserver.com" from="$[/system identity get name]@myserver.com" ;
/queue tree reset-counters-all ;
:log error "Queue Stats End"
Scheduler runs this script every midnight. The script, as is, takes about 1 minute to execute on a pentium computer so be careful if putting on a routerboard (especially since it requires 500 mangle rules and 500 queue tree rules)
It will end up on the wiki once i removed the excess code :sunglasses:
