101
February 20, 2023, 8:34pm
1
Hello. Help me, please!
I want to open a port for my virtual machine whose ip is 192.168.88.100 with port 7777 for UDP. Locally the server works, everything is fine. I write my external ip, then the port is closed, etc.
Device: Hap ac2
Settings default
RouterOS v7.7 (stable)
Address Acquisition: PPPoE
ISP: IP in stock
The settings I made:
ip
firewall
nat add
chain=dstnat
Dst. Address= my isp ip
protocol= 17 (udp)
dst-port=7777
In. Interface List= WAN
action=dst-nat
to-address=192.168.88.100 (ip virtual machine)
to-port=7777
config
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
Thank you in advance for your response
nichky
February 20, 2023, 10:28pm
2
add this and try again:
add action=masquerade chain=srcnat out-interface=bridge
101
February 21, 2023, 7:52am
3
I added.
Port 7777 is closed on my ip
Your ISP may filter game ports. Ask them, is it, or not.
Sob
February 21, 2023, 12:33pm
5
For start, your “my isp ip” is public (not 10.x.x.x, 100.64-127.x.x, 172.16-31.x.x, 192.168.x.x) and directly on your router (you can see it in IP->Addresses), correct?
101
February 21, 2023, 1:12pm
6
They said that all the ports are open and set up the router
101
February 21, 2023, 2:41pm
7
https://bayfiles.com/ra28y6Z9y9/1_png
https://bayfiles.com/qa2cy0Z8y9/2_png
Sorry, by that title “Why doesn’t the port open?”
Gain this reply: “You have try to turn the knob or use the key?”
anav
February 21, 2023, 4:33pm
9
Really, is that where you went…?
Shocking, I thought it would have been,
… if its open we must drink it soon, otherwise it will go bad.
OR
The port is closed due to an explosion at the docks…
101
February 21, 2023, 5:07pm
10
Very excellent response from "guru". I am not a sysadmin, and I am entitled to make a mistake. I was looking for information on how to solve my question, so I come to the forum when I can no longer solve it at all. For me it is a dark forest in the light of day.
101
February 21, 2023, 5:08pm
11
OR
My answer to rextended is the same as yours.
Спасибо!
You took it from the wrong point of view, it was just a joke to defuse, given the title it came naturally to me.
Too much seriousness in life kills earlier.
Don't take me seriously just because it says "Forum Guru"...
Trust the guru
101
February 21, 2023, 5:22pm
13
Trust the guru
Okay, I hear you). It's just that the language barrier makes it hard to take jokes.
Sob
February 21, 2023, 6:44pm
14
Is it also language barrier that makes you answer only half of questions? Now we know that if it start with 91, it’s public address. But we still don’t know it your router actually has this address. Once again, look in IP->Addresses, is this address there?
101
February 21, 2023, 6:55pm
15
Sorry.
IP → Addresses, is this address there? Yes
https://bayfiles.com/26d42fZ1ye/Screenshot_at_2023_02_21_20_52_14_png
Sob
February 21, 2023, 9:06pm
16
Yes, it’s correct and it should work. Even if it wouldn’t work completely, you should at least see some incoming packets, counters for dstnat rule (columns Bytes and Packets) should increase. How do you test it?
101
February 21, 2023, 9:11pm
17
I connect to the server, or use sites where you can check any ports.
Can you please tell me if I have the right NAT?
Sob
February 21, 2023, 9:16pm
18
Not from a screenshot, it can hide some things. But based on your description in first post it should be ok. To be sure, try to run this in Terminal:
/export file=myconfig
and then post content of created myconfig.rsc here in code tags.
anav
February 22, 2023, 2:36am
19
Finally Sob you are getting the hang of helping, next time ask for the config on the first post ;-PP
101
February 22, 2023, 8:36am
20
by RouterOS 7.7
# model = RBD52G-5HacD2HnD-TC
# serial number = XXXXXXXXXXX
add admin-mac=XXXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=XXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=XXXX wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=XXXXXK
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment=forum out-interface=bridge
add action=dst-nat chain=dstnat comment="Open port 7777 for CT101" \
dst-address=91.92.2.111 dst-port=7777 in-interface-list=WAN protocol=\
udp to-addresses=192.168.88.101 to-ports=7777 #192.168.88.101 correct for Virtual Machine
/ip hotspot service-port
set ftp disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
add address=2001:XXX::/32 comment="defconf: documentation" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=MY IPv6::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=XXXX/XXXXX
/tool mac-server
/tool mac-server mac-winbox
