Why is bonding speeding down my links?
Hi, I use 2 RB450 between them are 2 (external) radio links 1. in 2,4, 2. in 5 ghz.
Why is the result slower as each link for its self?
The reason i want to use this is a: redundancy and b: double the speed.
bonding mode rr.
An answer will be nice.
Jan-Willem
bonding will only go as fast as N * the slowest link… if you have a 512k and a 1024k link bonded, you would only get 512k * 2 = 1024k. If both links are the same speed you will get about 80% or so because of overhead and tcp retransmissions.
Sam
