There does not seem to be a definitive method to access Webfig on my RB2011 router from the internet. Is it actually possible? I have tried lots of different ways from many sites but none work (NAT, Firewall etc).
It’s not clear why you are unsuccessful, so I can’t suggest a specific wiki page. Need to see the configuration page first.
Basically access from the internet is controlled in the “firewall → filter” menu. if you disable the rules that “drop” the traffic in the “input” chain, it should work from the public IP.
But this is dangerous and opens the router to anyone
I found the “Firewall Router” tick box. It was on the “Home AP” Quick set, not the default “WISP AP”.
As indicated by some posts, I have added a NAT rule on port 443 to get through to my Fileserver and that works whether I have the “Firewall Router” ticked or nor. However, if I create a NAT rule from port 81 back to the router itself (192.168.1.1 port 80) it only works with the “Firewall Router” unticked.
That seems to indicate the rules used for the ticked “Firewall Router” are too tight. However, your last post seems to indicate that I should not use the rules created when I untick “Firewall Router”.
So, as my router is attached to the internet (and is my firewall), it seems dangerous to untick “Firewall Router”.
How do I adjust the ticked “Firewall Router” rules to allow access to my router from the internet?
To access a server within the internal network from outside, you need to set up a NAT rule.
To access the router itself from outside, you need to set up a Firewall rule to open up the port you want to use.
Perhaps that is obvious to some, but it confused me a lot when trying to figure out why I needed to use two different methods when opening up routes to the internal network.
For access to the Router itself from the Internet, I use this firewall rule. For my simple mind, this works because it opens up port 80 on the first thing the internet hits.
For access to my fileserver from the Internet, I use this NAT rule. This works because it is able to point the traffic at a different IP on the internal network (Network Address Translation).
