i have a ccr in datacenter A and another ccr in Datacenter B both of them are using a same carrier and i am advertising x.x.x.x/24 from both of them but in Datacenter B i advertise this prefix with 3 time prepend or weight 80 but no one in world learn this route!
this is my configuration on Datacenter A :
i set bgp-out filter for my Peer in datacenter B with this rules :
prefix: x.x.x.x/24 action=accept
prefix: 0.0.0.0/0 action=discard
prefix: x.x.x.x/24 set-bgp-prepend=3 action=accept
and there is a note that my routers on Datacenter A and Datacenter B does not have bgp connection they have their own bgp connection with their upstream router in datacenter and the only connection they have is IPIP Tunnel but both of them are in same asn and advertise same prefix,
any idea why weight and prepend not working ? because i want datacenter b will be my backup link.
and also another note is with this configuration only my receive packets will be redundant how can i make my send uplinks redundant ? because our monitoring team should check when one of them goes down then set PBR for fix the send link . for example when datacecnter A goes down my bgp will advertise from datacenter B but my users under datacenter A will be still down. any idea how can i make this automatically ?
thank you,
