Wi-Fi performance bad on RB4011 - possible misconfig
Can get up to 450mbps using btest in my hap ac2, this is my config if it helps
add authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" \
    group-key-update=1h mode=dynamic-keys name=main supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] amsdu-limit=2048 amsdu-threshold=2048 band=\
    2ghz-b/g/n country="united states" disabled=no distance=indoors frequency=\
    2462 installation=indoor keepalive-frames=disabled mode=ap-bridge \
    multicast-buffering=disabled multicast-helper=disabled security-profile=\
    main ssid=network wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] amsdu-limit=2048 amsdu-threshold=2048 band=\
    5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country="united states" \
    disabled=no distance=indoors frequency=5660 installation=indoor \
    keepalive-frames=disabled mode=ap-bridge multicast-buffering=disabled \
    multicast-helper=disabled security-profile=main ssid=network-5g \
PD: I live in front of some old buildings with lots of WISP and 4G antennas, the non-DFS spectrum is extremely crowded as 2.4ghz is, so using a free DFS channel helped me
I don’t know why, but there is no “one for all good” wifi configuration, if even two same type of models, with same configuration, acts totally different way, not to mention of different models.
Yea, I know, now some will write a long list of all kind reasons (different environment, different clients, different users, different weather etc), but somehow other brands do not have such problems. Maybe Mikrotik builds hardware from disqualified parts and as their tolerance is very high, then users must tune and tune to achieve the basic conditions, when some other brands almost does not include any tuning options and still they work well and perform better.
Ok thanks! I was able to solve the P throughput problem on my PC, I have relocated its antennas. Now I have P Throughput around 350000. I think this seems much better. TX rate 390Mbps (almost same) RX rate 702Mbps. Signal is still -61 dB
True throughput still around 210Mbps.
No, the RB751 is around halfway as my computer (in distance and in direction as well), so it is not that close, also in a different room.
In the weekend I will try to relocate the router (I think this might be the root problem, because even small changes of the router location at that point causes significant differences).
Also I will try Snooper and see if I can understand something better.
Thanks! I also think there is no copy paste solution, but I have some things which is really different from yours. And I don’t know if it will make any sense.
Like amsdu-limit/threshold, multicast-helper. buffering, etc… Why did you set those?
There is no clear answer, seems it helps in some cases stability and some clients (ios) connection, for me amsdu 2048 made things worst. For example my current config is:
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-g/n basic-rates-a/g=12Mbps,24Mbps basic-rates-b="" channel-width=20/40mhz-Ce country=no_country_set disabled=no \
    distance=indoors frequency=2437 frequency-mode=manual-txpower hw-retries=5 installation=indoor keepalive-frames=disabled max-station-count=300 mode=ap-bridge multicast-buffering=disabled \
    multicast-helper=disabled rate-set=configured security-profile=xb ssid=xb supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" wireless-protocol=802.11 wmm-support=\
    enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=1 band=5ghz-a/n/ac basic-rates-a/g=12Mbps,24Mbps channel-width=20/40/80mhz-Ceee country=no_country_set \
    disabled=no distance=indoors frequency-mode=manual-txpower installation=indoor keepalive-frames=disabled max-station-count=300 mode=ap-bridge multicast-buffering=disabled multicast-helper=\
    disabled rate-set=configured security-profile=xb ssid=xb supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
And like I said, strange and unlogic, but true in my case, disabling route cache and fasttrack gives better speed for wifi, however, as my wan is 4G, which speed is much lower then Your, then it may not help You at all. But You never know, until You try.
What makes me wonder is Mikrotik stability problem, for example, yesterday evening I played a bit with amdsu settings and speed was 5 m away kind of 30/30 (yes, it’s still pathetic, as wan is about 80/50). Today morning speed was 5/9, tried about 5 times, same result, then via Mikrotik app I opened same amdsu setting, there was 8192, deleted last octet, inserted again and saved (so actually I saved config without any actual change) and speed was again 25/25.
What is going on? Does Mikrotik fall into some standby mode or what?
Now I have tried snooper.
It reported a few channels which don’t have any bandwidth at all, I have selected one and I get a slightly better results now. Around 10% better. But still far from what I want.
Next I will try to move the router a little bit…
I also did some tests on the RB4011 5 GHz performance this weekend (using ROS 6.47). It looks like it does not like to transmit data. Using iperf3 over the wifi-connection, the RB4011 was able to receive about 300 MBit/s from a 2x2 client (Intel AC7260), but it only managed to send 80 Mbit/s back to the client. Both under almost perfect radio conditions. I also checked the same client’s performance on several last-generation 802.11ac wave 1 APs from different manufacturers, and always got better performance.
Connecting two RB4011, standing on the same table, on 5 GHz, it looked that the one in AP mode was really slow in increasing TX rate, while the one acting as station seemed to behave about normal. Running Ping Speed over the 5 GHz link for a few minutes, they finally achieved a decent average speed, but the overall experience in realistic scenarios was not satisfactory.
Hopefully, new drivers will fix this at some point.
I’m still on 6.46.6 and I hoped 6.47 will come with some improvements! Anyway thanks for your detailed tests. However I’m still not able to reach even 300Mbps on 5GHz with RB4011.
Which is a shame because a friend of mine bought an hAP ac2 almost the same time when I bought the RB4011 and he gets much better speeds with that one (around 450Mbps down).
I have read that hap ac2 had similar problems before and updates slowly fixed it. I don’t know if this is the case with the RB4011 also. Looking at the specs sheets, it seems that besides both router is arm based, nothing else matches between the 2 routers (completely different wifi chips, cpu, etc…). So I just can hope that this will improve over time.
One thing I did not test is moving the router in the house (which is not that easy for me), but I will test it soon. I will be happy if I can get around 300-400Mbps speed…
Also I can somehow confirm you. I only have one RB4011 and sometimes I see when starting a speedtest it start at around 50Mbps and slowly increases for around 210Mbps. This happens 1-2 times out of 10. In other cases the speedtest jumps to around 250Mbps and slowly decreases until 210Mbps…
Once I was able to get around 335Mbps speed, but I don’t know why and how… I just tested it randomly (nothing changed) and it jumped to 450Mbps and avaraged around 335Mbps down. However right after starting a new test (same position) I was not able to get more than 250Mbps… So it really fluctuates in speed and I don’t know why…
Setup:
  • Near range (2meter) between client and AP
  • iperf3 on Android / MacOS
  • iperf3 on Rasp4 with Ethernet connected to RB4011
  • RB4011 4x4 ROS 6.46.6, reset to default, 20/40/80MHz channel and Wifi security added (to avoid also anyone connecting to the unit)
  • Add also the country in Wifi interface to ensure I do testing which actually means something.
  • No other ROS changes done.
    Any other setup than above might give wrong results… !!!
Average throughput over 30 seconds:
  • 520Mbps TCP DL with 3x3 client
  • 400Mbps TCP DL with 2x2 client
If you do that test and get lower numbers, then your Wifi environment is crowded (mine is not really in 5Ghz) or your unit is defective…
I guess its rather first one for you…
PS: DFS channels might play or not a role in your country. I often do test in the non-DFS channels but those are the most crowded ones
in urban environment problematic.
Did similar tests today. Only I did not reset the config to default on RB4011, but everything is similar. iPerf3 server on Raspberry 4, 2x2 client close to router, I got around 250Mbps speed…
I implicitly assumed this, but to be sure, I use 80 MHz capable clients.
You can check in the Wireless “registration” tab that they do receive and sent with 80 Mhz
and 2 spatial stream.
Same clients here (I get around 800Mbps Rx rate 80Mhz/2SP/SGI)
Exactly. AP RX rates I get >1000Mbps with MacPro 3x3 but on AP TX I rarely go over the 800Mbps rates…
So client UL is a but better than DL.
On the 2x2 client I get 800mbps rates on both Rx and Tx.
PS: I keep AMPDU priority as default (only “1” checked). I see bad performance when enabling the others.
I really keep all “Wifi” settings to default.
A surprising performance hit, bad performance with A-MPDU enabled. These are needed for high performance throughput, by avoiding a lot of overhead.
If most is default (no extra added mangle rules to set the priority) then all is priority 0 , and only the priority zero setting for A-MPDU is used, and that is enabled by default.
Mikrotik default configurations never set the priority.
Aggregation is good for throughput (reduced overhead), its bad for latency and jitter. So it should not be set for priority 6 and 7 (eg. voiceIP)
Expected performance without A-MPDU set: http://forum.mikrotik.com/t/how-to-get-rid-of-slow-wifi-can-it-be-done/139640/1
I did not change AMPDU priorities and I have 0 checked.
So you say you only have “1” checked?
Anyway it seems that the placement of the router is also wrong. Did iperf tests again from different positions, and some place I was able to get around 350Mbps average. So I will try to place it somewhere else first.
What I don’t know is that other (online) speedtest tools give really fluctuating performance (which I can sometimes see on iperf also). I know that this is an online service, etc but my Raspberry Pi does speedtest tests on a selected server periodically and it always gives me 500Mbps (through cable) which is my ISP maximum. Same server on a wireless client, max 210Mbps. iPerf sometimes gives 350Mbps if I can place the wireless device correctly…
Well, another observation through longer time… It seems that only speedtest is slow(er), using P2P connection (like torrent client) is much faster, even on my personal computer 15m away from the router.
Speedtest (does not matter which - ookla, fast.com, etc… or even local iperf) usually gives 180-190Mbps here, torrent client can reach up to 36-37MB/s which is almost 300Mbps… Still far away from 500Mbps which I want to achieve, but this is much better. Though testing it like this is much harder, so the question is, why speedtest is slower than other connections?
I don’t care if the speedtest is not as fast as the actual connection is, but I might try again different configs, channels, etc and would be great if I could easily test it with a proper tool…
This is a post about Wifi problem, is your question still Wifi related?
If so you CAN NOT test Wifi connection with Ookla Speedtest. Well you can, but your results do not say anything
about the Wifi, but about the complete system.
So the only way to do this is test Wifi connection between the AP and the client ONLY, and enusre othe elements used
to test support at least max. Wifi speed (or 1Gbps).
Such a test will show you your Wifi performance and then you can start playing around (a bit) with Mikrotik Wifi parameters.
Use Iperf3 is simplest and most reliable solution if you do not have professional Wifi test equipment.
Giving advice based on results obtained via “speedtest” is in my sense point less…
If you talk about ethernet speed, then torrent do use many connections in parallel, which is often better to “load the system” up to its maximum,
versus “single stream” testing. Even compared to ookla “multi” setting, the torrent will have many more connections.
This could be reason you see highest speed with torrent (and they all use UDP, which is simpler/faster than TCP which is used by Speedtest…!!!)
I see lots of reference to theoretical speeds, 867, 1300, etc… Remember its marketing hype as those are two way added speeds.
The most ludicrous is the term ooh aahh 1750 which is adding both 2.4 and 5ghz two way streams 450+1300.
Or 867+300 = ~1200 on the packaging.
Consider 1300 for example, its two way tx and thus when we are talking uploading or downloading one should be discussing 650-prop losses as the starting point.
Using the MTUNA certified 1/3 rule any turkey looking to get beyond 433 speed, needs to be bitten by a llama and endure his/her flatulence!! Sure under ideal conditions of no interference and LOS on 5ghz… but most have competing elements in the home of all sorts from house wiring, type of lighting, appliances etc (worse in apartments) and walls of unknown characteristics. Further as has been noted a mix of wifi devices can seriously impinge upon ideal performance. Obviously 2.4ghz due to progopation will travel further and be more useful over a longer range than 5ghz. In fact 5ghz in a house of any size is useless as a single entity and one needs multiples regardless of vendor. Even a single 2.4 may not be suitable for a larger home.
The frustration is that I can setup a TPlink eap245 plugNplay in the place of a capac, and without any fuss at least equal and surpass the cap performance without any tuning (to be fair it has more chains too). Mind you the capac with routerOS has many other pluses and capabilities that the TP link lacks. The key is for MT to ensure that the wifi is either EASY to configure (comes with a stock setting equivalent to other vendors plugNplay) and what I was hoping for most, was the ability to tailor those settings (one size fits all) to size to my location. However even an expert and generous man bpwl, with great knowledge and patience is still befuddled by the lack of information available. So concur, that MT is not doing a service to its customers at the moment on the wifi side. It seems they have made a half-hearted effort to provide some features but not all and no instructions… and then gave up on putting any more resources into wifi (well other than into products to sell).
I have stated this before … they should hire bpwl on a contract and let him work with the programmers and come up with a useful guide as well as any changes need to the code to ensure that users can optimize their devices.
Yes this is still a question about Wi-Fi.
Yes, I know how TCP/UDP works… and I know that you can’t trust speedtest on this, but iperf seems to perform worse than it can actually handle. iperf gives around 230 Mbps (local server - the server is connected wired to the router - so no 2 clients using Wi-Fi extensively), which is the same as speedtest…
Wired client can easily use 500 Mbps even on ookla speedtest (which is my max isp speed).
But I slowly accept that I can’t get better results with this Wi-Fi chip… also what I can’t understand is that using a COMPLETELY empty channel 100-116 gives worse results than it does on 52-64 which always has 1-2 AP on it as well…
Yes I know and I never assumed that I could get even 1Gbps Wi-Fi speed with this device… Though 400-500 Mbps should be there on 5Ghz I think.
