Hello everyone, I turn to the community for a problem related to a wifi performance issue with my router board, despite I have an incoming line WAN of 1Gbit/s, with the wifi I can not get more performance than 150/200 Mbit/s, I understand that this depends on various factors, but first of all I would like to know if there is something to improve in the configuration.
No problem in LAN (ether2)
add bridge=bridge comment=defconf interface=wlan2
ps: i’m only interested in 5GHz network, unfortunately I have a device that doesn’t support ac band, so i have to activate n as well.
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country=switzerland distance=indoors frequency=auto installation=indoor
mode=ap-bridge ssid=MikroTik-139F8C station-roaming=enabled
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX
country=switzerland disabled=no distance=indoors frequency=5240
installation=indoor mode=ap-bridge skip-dfs-channels=all ssid=
MikroTik-Home station-roaming=enabled wireless-protocol=802.11
wmm-support=enabled wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-polling=no
set wlan2 enable-polling=no
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik wpa-pre-shared-key=
wpa2-pre-shared-key=
no particular firewall rules
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
add action=masquerade chain=srcnat comment=“defconf: masquerade”
Model: RBwAPG-5HacD2HnD
RouterOS v6.48.1
