You can’t make any promises with nlos links. My long range link mentioned above will not work with 2.4Ghz but will work with 5Ghz.
Rule 1) nothing is certain with nlos links.
Having said that. I think your best solution may not be wireless. If you can get an antenna into the basement then why not a small hex lite or hap mini and vpn over to your sensors? Or, be an absolute madlad and run the v7.1 beta and use ZeroTier.
after exploring all the options I have, nothing worked.
No LTE connection, no Wifi 2.4 GHz / 5 GHz link possible but what I found is a lot of open WiFis in the building
where garage is placed. So I did a bit of research went to couple of bars in the building, got couple of wifi passwords
and will connect to one of them and put my sensors online
For now I managed to get stable connection of 4-5 mbit/s with one of the bar APs with TP-Link access point and 20 db panel antenna I had laying in the garage.
Now I need to connect another AP to TP-Link in order to get garage covered by WiFi signal.
Would HAP Lite be OK or do you recommend some other Mikrotik device (with possibility of connecting external antennas) which I can use instead of TP-Link and to esatblish connection to bar AP and to act as AP for my garage. Hope it makes sense.
current status:
TP-Link in client mode (panela antenna) - connected to bar AP, additional Dlink AP connected by cable to TP-Link, Dlink in AP mode covering garange
what I’d like to do:
use Mikrotik equipment with external antenna to connect to bar AP and Mikrotik to be as well AP for my garage, both client and AP in single device
They don’t mind, I got 4-5 mbit/s max during testing period but I need maybe couple of kbit/s non-continuous since sensors update data every 10 min.
Anyway I’ll go with RB433 and 2x 2.4 GHz network cards, one as a client and the other as AP.
