Hi, I’ve been using so far wireless equipment only between clients with minimum obstacles but now I have a need to connect two clients apart 40-50 meters, one is in the garage (one level underground)
and the other client is on a building across the street on the second floor.
If there would be no concrete of the garage/building structure of the first client, they would see each other.
Connecting them with UTP cable is not an option, only solution is to use Wi-Fi connection.
In your opinion would two panel antennas of 15-20 dBs establish some “stable” connection between clients?
Any other suggestions?
Hi, thanks everyone for comments and suggestions,
I’ve purchased one TPLINK and DLINK access points, 2 panel antennas 16 dbi each, will test the connection in following days and update.
Do you have any idea how much bandwidth 2 cameras require? A plain 2MP IP security camera requires at least 4Mbps(with h264 enabled). 2 cameras and sensors, etc. - minimum 10Mbps.And we are talking about stable 10Mbps, not peak 10Mbps. And you told us that one of two antennas will be one level underground and 50m away. Even if you have direct line of sight, speeds at this distance, unless using decent equipment are not guaranteed.
What you need to do is run cable to achieve a LOS between the two panel antennas. That is how WIFI works in the pt to pt scenario.
There are places where pipes wires, and other items get passed between floors FIND it, use it.
If you cannot do that, why are you wasting your money??
Thank you all for proving me I was not right.
I couldn’t get 2.4 GHz signal out the underground garage.
Tried with 2 panel antennas and later with 1 panel and Ubiquiti 13 dbi omni antenna.
Since I can’t get UTP cable between 2 buildings another solution (maybe) is a GSM/LTE model in the garage, depends again on the signal.
May I ask why you can’t use a cable between the buildings. I mean, there must be a way to enter and exit the buildings somehow, right? What about a window or air shaft?
Well, he explains that the other building is “across the street”. In many countries that means you cannot run a cable because you are not allowed to string cables across a street or dig a trench to put them under.
However, there could be the possibility to run a cable upward from the underground garage and attach an antenna to the building above street level or on the roof, and then beam the signal across the street. That should work, but of course we cannot remotely judge if that would be feasible.
I would use an external LOS connection between the two builings using 60hz tech.
then wire from there to the desired internal locations. All depends on what can be done from external to internal on the buildings.
Enter from roof side, or run conduit down a wall to an entry point etc… https://mikrotik.com/product/wireless_wire_cube
Unfortunately garage is in another building, I’m not allowed to put anything on the walls/roof of the building.
Garage space has a main entrance door and from there it is 15 meters to my garage doors.
Since WIFI doesn’t pass through concrete I’ll test if I can establish connection with LTE/cell modem
I personally run a non-line of sight wireless link for my home internet connection using the following config on a pair of these https://mikrotik.com/product/RBLHG-5HPnD-XL
This link is approx 3 miles long and runs through dense forest. I get a stable 15-20Mbps connection
config:
# oct/02/2021 15:48:01 by RouterOS 6.48.4
# software id = XXXX-XXXX
# model = RBLHG-5HPnD
# serial number = XXXXXX
add name=bridge1 protocol-mode=none
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name="Eastern Sunrise" supplicant-identity="" wpa2-pre-shared-key="******"
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode ampdu-priorities=0,1 antenna-gain=0 band=5ghz-onlyn channel-width=10mhz compression=yes disabled=no distance=10 \
frequency=5175 hide-ssid=yes ht-basic-mcs=mcs-8,mcs-9,mcs-10 ht-supported-mcs=mcs-8,mcs-9,mcs-10,mcs-11 hw-protection-mode=rts-cts installation=any mode=bridge nv2-cell-radius=10 \
nv2-downlink-ratio=75 nv2-preshared-key="******" nv2-security=enabled rate-set=configured security-profile="Eastern Sunrise" ssid="Eastern Sunrise" tx-power=30 tx-power-mode=\
all-rates-fixed wireless-protocol=nv2 wps-mode=disabled
add bridge=bridge1 interface=wlan1
/system identity
set name="The Eye of Sauron"
/tool romon
set enabled=yes
edit: I think you could have similar results on a 50m link unless this concrete is more than 2ft thick or has a ton of rebar inside for reinforcement…its really hard to make promises with NLOS links. you really just have to try it and see.
