Wifi Extender setup on boat
Hoping I can find some direction as I m not an IT newby but the Mikrotik products have me stumped. I have a boat, at a marina that has wifi that I need to use. They use Ubiquiti AP’s and apparently only transmitting on 2.4ghz. Just purchased MikroTik hAP ac lite Dual-concurrent Access Point (RB952Ui-5ac2nD-US) and a GrooveA 52 ac Outdoor CPE 802.11ac Gigabit PoE 2.4GHz 5GHz 5W OSL4 8dBi. I setup the Groove in bridge mode from quickset menu after connecting to marina wifi. Unfortunately the marina network is on same 192.168.88.1 as the Mikrotik. Connected this to hAP router and setup LAN wifi for boat. Connection works but freezes as I assume everything is on same 192.168.88.XXX and I cannot access anything while on marina wifi. I tried changing router LAN IP and can get to router but no longer internet. Is there a best practices or simple method to set these devices up correctly?
Welcome to the forum :smiley:
Can you export your configuration files from both devices and post them here ? Just remove any potential sensitive data.
That way you will probably get your answer faster.
It’s a simple manner to change the IP range on the Mikrotik so there is no conflict. As gigabyte091 said, please post your configurations. Since you are new, I will tell you how to do that. To export and paste your configuration (and I’m assuming you are using WebFig or Winbox), open a terminal window, and type (without the quotes) “/export hide-sensitive file=any-filename-you-wish”. Then open the files section and right click on the filename you created and select download in order to download the file to your computer. It will be a text file with whatever name you saved to with an extension of .rsc. Suggest you then open the .rsc file in your favorite text editor and redact any sensitive information. Then in your message here, click the code display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
[/code]
For the hAP router. Having trouble now getting back into Groove which is set to Bridge
# jan/16/2024 20:45:35 by RouterOS 6.48.6
# software id = 0KEQ-6APV
# model = RB952Ui-5ac2nD
# serial number = HCS0870W3Q3
add admin-mac=18:FD:74:48:DC:F2 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united states3" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="Emmi 2.4" wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid="Emmi 5" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/16 comment=defconf interface=bridge network=\
    192.168.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.0.0/16 comment=defconf gateway=192.168.88.1 netmask=16
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add disabled=yes distance=1 gateway=192.168.88.1
/system clock
set time-zone-name=US/Eastern
/system identity
set name=RouterOS
/system package update
set channel=upgrade
/tool mac-server
/tool mac-server mac-winbox
