Well I do because it preludes my laptop falling back to 2.4GHz with a perfectly strong signal ![]()
Same issue started happening after I connected my new company laptop with Intel Wi-Fi 6E AX210 adapter.
I had no problem with using an iPhone that had “Private Wi-Fi Address” turned on and another laptop with Intel Wi-Fi 6 AX201, and I used those for a long time.
Maybe this iPhone setting is only problematic if certain other wireless devices are present? Or maybe my company laptop has some weird Wi-Fi setting?
The 5GHz wifi completely stops working after this. The interface needs a disable/re-enable to make it work (or a device reboot).
I have Intel AX211 in my laptop, no issues whatsoever connecting to AX3.
But what’s the difference ?
