Hi everyone. today I decided to upgrade from routeros 6 to 7 on my RBwAPG-5HacT2HnD however I noticed some anomalies such as:
in the Wi-Fi interface it has not created the Wifi1 and 2 connections and the channel card is not present
I tried to manually install loaded missing ARM package but it doesn’t install anything.
I tried to downgrade to version 6 of the OS but nothing happens. In short, I’m stuck here without being able to create wifi networks.
Isn’t it MIPSBE? (not ARM):
https://mikrotik.com/product/RBwAPG-5HacT2HnD
It is indeed, hence you should install the wireless-7.xx.x-mipsbe.npk package (which is located in the \MIPSBE\Extra packages file.
You need to install the Wireless package, what you have open is essence Wifi CAPsMAN for wifi-qcom/wifi-qcom-ac, this menu is also used for local interfaces running these drivers.
Well, it is MIPSE platform and not ARM. You need the “wireless” package from the extra-packages ZIP.
Thank you guys. All done. I installed right packages. But i guess i cant use wifi but only wireless
Correct. You can’t use “WiFi” menu for your local wireless interfaces. But if you have Mikrotik AX devices somewhere on your network, you can use the “WiFI Capsman” to manage them.
