wifi limit 20 mbps
just set up wifi interfaces on Chateau 5G ax. When connecting through ethernet cable the downlaod speed is 150-200 mbps. However when connect via wifi, the downlaod speed only 20 mbps.
Many thanks,
Without more info, lots of issues could be causing this…
  • firmware/software version (v7 still has issues)
  • interfaces not set properly
  • interference from neighbouring devices on 2.4 GHz
  • Distance and walls (worse on 5 GHz)
  • Device not behaving as expected with the MikroTik radio
  • Bad configuration
I’ve seen reports of 600-800 Mbps on these new AX devices, so 20 is not normal. BTW, user bpwl has posted lots of great advice over the years on how to troubleshoot/tweak wireless issues if you do a search…
sounds like you might have “tkip” ciphers enabled in security profile
or maybe using 2.4GHz anywhere outside middle of desert …
