Hi All,
I’m new to MikroTik and just bought a mAP Lite. I came across a problem when setting up WIFI password - once I set a password and save in WinBox, the WIFI got disconnected and a new WIFI appears. The new WIFI name is its previous name plus a number “2” at the end. And if I connect to this new WIFI, I do not need to enter password.
Could someone please tell me where I set wrong? Thanks so much!
As WirtelPL suggested in post 2 the situation involves Windows 10 and not your Mikrotik mAP or Winbox. It is not a Windows error or a Mikrotik error.
If you go to Network and Internet and click on Wifi then select Manage Known Networks you will see 2 entries for your network name. One has the number 2 after it. Click on each name and select “Forget” then go back to your computer wireless, find your network name and login using your wifi password. This will be saved by Windows 10 and you will not be asked by Windows for the password on subsequent login’s.
