Hi there,
I do have a problem to set up wifi on a hAP-ac² with ROS 7.15.2.
I configured a security profile with WPA3-PSK, a passphrase and WPS disabled. The security profile is linked to the wifi interface.
I can see that passphrase and WPS setting is set in the interface, but the authentication type is unchecked.
The WiFi appears to be open. Only after I set the authentication type manually in the interface it is secured.
Furthermore, when I try to connect to the wifi the connection request is declined. I checked the passphrase several times.
The same settings on a hAP-ax³ setup on an earlier ROS version, but upgraded to 7.15.2 works perfectly well and is secured without setting the authentication type manually.
I’d appreciate any suggestions.
Cheers,
