Hi, I’m trying to setup a wifi access point with a vlan but can’t make it to work properly. When trying to setup a DHCP server for the vlan interface it always says Invalid.
Can anyone help please?
# 2023-10-22 15:53:17 by RouterOS 7.11.2
# software id = 0527-TI44
# model = C52iG-5HaxD2HaxD
add admin-mac=18:A4:8B:CD:16:2F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=WAN poe-out=off
/interface wifiwave2
set [ find default-name=wifi2 ] channel.skip-dfs-channels=all \
configuration.country=US .mode=ap .ssid=AP disabled=no name=\
"WIFI 2.4G" security.authentication-types=wpa2-psk,wpa3-psk .wps=disable
set [ find default-name=wifi1 ] channel.skip-dfs-channels=all \
configuration.country=US .mode=ap .ssid=AP5 datapath.vlan-id=10 \
disabled=no name="WIFI 5G" security.authentication-types=\
/interface wireguard
add listen-port=30330 mtu=1420 name=wg
/interface vlan
add interface="WIFI 5G" name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.2-192.168.0.254
add name=vlan_pool ranges=1.0.0.2-1.0.0.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add address-pool=vlan_pool interface=vlan10 name=dhcp_vlan
/interface bridge filter
# no interface
add action=drop chain=forward in-interface=*D
# no interface
add action=drop chain=forward out-interface=*D
# no interface
add action=drop chain=forward in-interface=*E
# no interface
add action=drop chain=forward out-interface=*E
add bridge=bridge comment=defconf interface="WIFI 5G"
add bridge=bridge comment=defconf interface="WIFI 2.4G"
add bridge=*19 interface=*15 pvid=2
/ipv6 settings
set max-neighbor-entries=15360
add comment=Br5 interface=*19 list=LAN
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.100.100/24 comment=wan interface=ether1 network=\
192.168.100.0
add address=10.0.0.1/24 comment=wg interface=wg network=10.0.0.0
add address=1.0.0.1/24 interface=vlan10 network=1.0.0.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=1.0.0.0/24 dns-server=1.0.0.1 gateway=1.0.0.1
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=\
192.168.0.1 netmask=24
set allow-remote-requests=yes servers=192.168.0.3,192.168.0.9
add action=accept chain=input comment=wg dst-port=30330 protocol=udp
add action=accept chain=input comment="wg " in-interface=wg src-address=\
10.0.0.0/24
established,related,untracked
invalid
in-interface-list=!LAN log=yes
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip ipsec policy
set 0 disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
