Wifi1 (2.4GHz) stops serving clients while a sibling AP on the SAME radio/channel keeps working fine — driver/AP-instance bug?
Hi all,
Running a hAP be³ Media, RouterOS 7.23.3 (stable), wifi-qcom-be package (ipq5300 chipset), latest stable, no update available. Tri-band local radios (wifi1=2.4GHz, wifi2=5GHz, wifi3=6GHz) plus a CAPsMAN-managed second AP.
The problem: every few days, wifi1 (and separately, wifi3) stop accepting/serving clients entirely. wifi2 stays perfectly healthy. Nothing recovers on its own, even after hours.
The most interesting/confusing part: I have a second SSID (domozolay, for IoT devices) configured as a slave interface bound to wifi1's same physical radio (master-interface=wifi1), same channel (2412), same tx-power. Right now, while wifi1 (the master AP) has zero connected clients and refuses to serve, the slave AP on that exact same radio and channel just authorized a brand-new client with a clean signal reading. So the RF hardware, the channel, and the driver's general ability to serve clients on that hardware are all clearly fine — the fault is isolated to the specific wifi1 AP/BSS instance itself, not the underlying radio.
What it looks like when it happens: sometimes the interface loses its running state and channel entirely. Other times (most recent occurrence), /interface/wifi/monitor wifi1 once reports state: running with a valid channel and normal tx-power — looks healthy — but registered-peers/authorized-peers both sit at 0 and the interface's bridge port shows inactive. So the state machine believes it's fine, but it isn't actually accepting associations.
Triggers observed so far (~5 occurrences in ~10-11 days):
  1. After a power outage / reboot.
  2. Spontaneously, mid-session, no obvious trigger.
  3. Right after a live config change on the interface while it was up (e.g. adding a steering= property).
What I've tried:
  • Disable/enable toggle — works roughly 1 out of 3-4 tries, unreliable.
  • Full router reboot — 100% success so far (3/3), but heavy-handed, and on this same box it has a separate ~50% chance of triggering an unrelated USB-storage-detection issue, so I'd rather avoid rebooting every time.
I also want to rule out my first suspicion: I have 802.11k/v steering configured on wifi1 but never touched it on wifi3 — yet both fail together each time, so steering alone doesn't look like the common cause.
Has anyone seen this — one AP/BSS instance on a shared radio silently stops serving while a sibling BSS on the identical channel keeps working fine, with no distinguishing log entry? Any known cause or fix on wifi-qcom-be/ipq5300 short of a full reboot?
Thanks!
Hey! I'm on latest 7.25.1 with the same device and having this issue often! This is SO annoying!
Any re-connect or switch to another wifi always fixes the issue but all that wastes a lot of time. We need a fix!
Edit: on a closer look mine is a different fault on the same device (hAP be³, 7.25.1, wifi-qcom-be). The radio keeps serving everyone else, but one client stays associated while its tx-rate sits at 1 Mbps, until it reassociates.
That sounds like the issue in this other thread (JFYI):
@jaclaz yes, I replied there, with a little script which helps me so far to fix that kind of issue (it doesn't happen often, but indeed is annoying when it is as it shows wifi perfectly connected but most of the apps are "loading" data endlessly). I hope it gets fixed on the OS level though.
