will mt perform better
Hi
I installed wi-lan vip 110-24. 11 Mbps, 23 dbm radio. It has different frequency for tx and rx. The link was 15 km, antennas used were 27dbi parabolic. I got the rssi of -62 but i could not get the stable link. Every other day we had to change the channels. We could never got stability. Will MT based radio will work better than wi-lan. This is the only question i have. Thnx in advance
regards
MT Router would perform better than that VIP, we got good result by replacing VIP with MT router .are you from India ?.
ya I’m from india
i too from india… :slight_smile: can u give me peronal email ID ?
nettlynx@gmail.com
This guy thinks so!
http://forum.mikrotik.com/t/2-4ghz-signal-issue-and-how-it-was-resolved/5710/1
