I’m using wireguard prolifically since RouterOS v7, for multiple site-to-site links and road warrior setups and it’s been a total gamechanger just as it is. Faster and easier to setup than all of the other VPN solutions in mikrotik IMO, except maybe zerotier. I’ve purchased hundreds of new mikrotik devices for various projects purely to create site-to-site vpn’s with wireguard.
Right now my biggest gripes with wireguard are:
At least one endpoint must have an open port / lack of NAT traversal (in which case I fall back on zerotier). I guess MikroTik aren’t going to prioritize some solution for wg NAT hole punching due to their partnership with zerotier now which would be somewhat unfortunate if true. I think support for tailscale would be an ideal/wonderful solution. Actually I think tailscale is precisely the solution that OP of this thread envisions when they say that wireguard is like a skeleton proof of concept and needs a layer of more configuration flexibility on top. So here’s my vote anyway for tailscale support in MikroTik
Lack of TCP support for unstable connections. Yes UDP is faster in general but sometimes TCP can help stabilize the connection. In such cases I fall back to SSTP where required
Manual MTU configuration that is required, and need to run GRE/EOIP over the WG tunnel in order to achieve 1500 MTU link / true Layer-2 bridging. The added overhead means reduced throughput efficiency, not to mention more configuration and IP addresses just to establish a single link
And a few other small issues which could be specific to MikroTik’s implementation, such as need to disable & re-enable a wg interface+peer pair if a remote endpoint IP address changes (dynamic DNS). But scripts can help with this. Overall I think zerotier and tailscale are more elegant and complete solutions which make wireguard’s configuration seem somehow archaic (and extremely limited, in spite of its modern and simplistic approach) in my opinion. It should become possible to use one mikrotik as a “cloud relay” type of server for the other nodes to get basic authentication and peer information and pass this on to the two endpoints so they can find each other and bypass NAT firewalls etc without dynamic dns and other legacy solutions. Then we’re really talking
If you are using it to connect your client to company HQ, and you see the HQ network as you would if you were there, it is VPN for me…
and technology behind does not make any difference from the users point of view…
Of course, not only by Mikrotik, but creating and managing users within ROS is certainly something that I expect…
You are probably right, but it does not hurt to ask…
Any other solutions you can suggest (because no , it’s definitely not my choice/preference to have terrible performance)? I’m referring to running a wg tunnel over things like pppoe connections where (at least with mikrotik currently) max MTU possible is 1480, or mobile/3g connections where MTU could be even lower, such as 1350 etc. That means the wg tunnel must run at 1400 MTU (or even lower) instead of the default 1420. What am I missing?
I guess with cases where CHR is used on cloud setups and jumbo frames is available, then this isn’t much of a problem. But in most use cases we’re talking about 1500 MTU or lower, in which case the wg tunnel will always run at a compromised lower MTU which will affect some applications and websites especially over SSL. I’ve seen several threads right here on the mikrotik forums (and elsewhere) of users running into issues where the problem seems to be MTU related (I faced the same issue, luckily EOIP came to the rescue)
I didn’t find a need for running such a bad setup, yet.
My WG endpoints sit at the lowest ISP MTU-60 just fine (IPv4 endpoints). Can’t think why I would need EOIP or l2 bridging between sites.
The fragmentation on your setup is stellar.
Lol classic case of “just because I don’t need it, no one else should”. How do you achieve a layer2 broadcast plane for device discovery etc with your routed setups? Exactly, you don’t. Sometimes there’s a need for site-to-site bridging even if you don’t realise this yet. My config might seem convoluted to you (don’t worry, it does to me too which is why I’m posting my feedback and suggestions) but it works perfectly and all the devices handle whatever I throw at them, so any issue you perceive seems to be irrelevant really. I’m still waiting for your better suggestions on how to achieve a more maximally efficient 1500mtu layer-2 bridge between Mikrotik devices constrained by lower-mtu transit interfaces, besides for my approach? I expect to wait for an answer indefinitely
I don’t need any of that between sites, and never will, hence I won’t search for a solution for something that I don’t need.
I only rely on L3 between sites.
Probably there isn’t a better solution to what you’re trying to achieve: http://forum.mikrotik.com/t/wireguard-and-eoip/154495/1
But still you can’t ignore the fragmenting.
I did some tests a while ago with proper MTU set in wireguard and .. not, the performance drop was terrible with bad MTU, no L2 bridging is worth that.
And it’s not something MikroTik specific, there isn’t any magical solution to your “problem”, there will be fragments.
Agreed. Fragmentation is a problem, as is WG’s own overhead provoking that very problem and causing the very MTU issues (which users invariably run into and then think the protocol itself is buggy, which you and me both know isn’t the case) as alluded to in my earlier posts. Fortunately, technologies like EOIP can solve the problem, albeit at the cost of even more overhead. But if that’s what it takes to defy the physical limitations and get the job done, so be it Something like a checkbox in Mikrotik’s wireguard configuration to “transparently” implement an EOIP layer over the tunnel would make configuration much easier, but obviously not go down too well with any routing-only purists around here xD I guess that’s why we have these conversations and how technologies evolve on a fundamental level at the end of the day
