i can’t login winbox through global ip from another ISP
Regard
Zahid
Regard
Zahid
Make sure that ISP is not blockin winbox port.
i m facing problem with same isp while subnetmask and gate is different also telnet is not working of mikrotik with putty .
/ip services export
/ip firewall filter export
detail as following of my mikrotik
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
[zahid@MikroTik] > ip firewall filter export
jul/13/2010 14:03:43 by RouterOS 2.9.27
software id = 5LKM-40T
Instead of using a pirated version, buy a license, run a recent version and ask for help again.
