*) fixed file upload via Upload button;
*) do not disconnect from router if none of the windows are open;
*) report error if telnet failed;
*) handle properly romon authentication failures;
If you experience version related issues, then please report them to support@mikrotik.com.
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
I would like to see a change that would allow you to do “multiple selects” from the “Show Columns” drop down menu that seems to be accessible from most windows instead of having to do one select/deselect at a time. That would be cool !!!
Finally, someone said it out loud!
Actually, we need checkboxes in those “Show Columns” menus!
However… I can foresee a reply from MikroTik where they’re going to explain that the new Winbox has such and such features, that renders this request unnecessary…
It is Microsoft Windows coding requirement not to store user data in program directories, but use the appdata directory for that.
And it is good, because you don’t want your program directories to be writable for the user.
I just finished configuring a large batch of routers, all of which opened two “RouterOS Default Configuration” dialog boxes.
This is not a new problem though, as it was also there before the v3.5 update.
Anyone else seeing this after resetting the configuration of a router?
I cannot configure existing VLAN entry in /switch vlan menu on CRS. “Qos Group” field marked by red color and even if i change it, color does not change. I can create new vlan entry without problem and i can manage existing entries with Winbox 3.4 without problems. Webfig also working.
Fix this please
On CRS226 - Can not set ‘Ingress Mirror To’ and ‘Egress Mirror To’ on any of the Switch Ports Interfaces. Label shows in Red and none of the three options will allow you to hit OK.
