šŸ“£ WinBox 4 is here šŸ“£
This is a big day for us and hopefully for you too.
WinBox 4 is finally here, for Windows, macOS and Linux.
Video: https://youtu.be/IOjkWJfmM24
We have worked on it long and hard, but it’s still only the first public beta, so a lot of things will change for sure. Not all features are there yet, they will come soon, and you will not have to wait another 15 years. There are a lot of new design decisions that might be hard to get used to, but we have chosen to leave most of the look familiar. Enjoy and write your comments, suggestions and wishes. Of course, a lot of design things will still change, we know there are some controversial things. Please try to report bugs first, design comments second.
  • We have Dark mode!
  • Apps for multiple operating systems!
  • Most importantly, since it’s all built from zero, we have the ability to quickly change and fix things!
Download link on our webpage: https://mikrotik.com/download
********** STATUS UPDATE Jan 27 ***************
Known issues to be addressed :
  • Some Keyboard shortcuts missing (currently only cmd/ctrl+W and Esc works)
  • Many UI buttons need Hover help text
  • Special characters lost when upgrading from WinBox3, but work fine when entered via WinBox4 (can’t be fixed!)
  • Skins not supported
  • Needs ability to ā€œselect many routers and connect to allā€ in Loader
  • Need auto light-dark mode setting based on OS settings
  • LTE Interface graphs are missing
  • Can’t ping DNS name
  • should be some vertical split control between the login/password on left and the neighbors
Paldies
Woohoo :tada:
Thanks Mikrotik team !
YAY for native Linux release…
What a new look interface!
Adding a YAY for native MacOS release…
Many thanks
Applause !!!
any way to import saved connections into winbox4 on Mac ?
It’s nice. And fast. Huuuuuge, but nice and fast.
Ctrl + Shift + W does not seem to work for me on Windows, though. Neither does to the ole ESC key.
wow, looking great so far. Thanks! Features I miss the most currently is the ability to import connections from Winbox 3.
EDIT: comment field is already there, only the column was hidden.
For me it works just fine.
Very good news! Congrats @normis, looking quite nice.
Looks very nice I must say. First thing however is that under interfaces the VRRP interfaces does not indicate if they are running master or backup. This means you have to open the interface to see the status, but this is a very very small complaint :slight_smile:
Comments are there, but the column ir collapsed by default. Click on the header (second column from left)
Looks really nice, and native Linux version works on first try. Thanks a lot!
But wondering… Is there a minimal RouterOS version required for this new Winbox?
Great, finally a native Linux version.
:tada::tada::tada::tada::tada::tada::tada::tada::tada::tada::tada::tada:
Any plans for native arm support? Would love running it on raspberry pi…
Where does linux version stores ā€˜saved routers’? Is there a way to import Winbox Loader Addresses?
See original post, jprietove
6.43
