I have some problem on Windows, after trying launch the app nothing happening. Nothing show, no menu, window, just nothing, in task manager it doesn’t even show the process. I need admin privilages to lauch the app or something else?
No, admin privileges are not required to run winbox, it only may ask you to add to the firewall but that’s automatic.
You may have some kind of “custom image” of windows, where everything is cut for “performance” reasons. Those sucks, but no one can guess what causes your problems. You can open Event Logs and see if there’s anything or try on a clean installation to determine if your Windows cause problems.
Nothing show in event log, app just not launch for no reason, winbox 3 works perfecly all time. I will try doing what u wrote, thanks
Use the main “WinBox 4 is here” thread for any related issues or questions: http://forum.mikrotik.com/t/winbox-4-is-here/178358/1
Sorry but I didn’t have a reply button last time I was there
I will post there
