hello everyone.
I managed to add simple queue for my local lan using Mangle and addresslist
now when i connect to my router using winbox the consumed bandwidth on my simple queue shows 16.kbps rx 354 kbps rx isn’t this unusual..
i am only connected to router no bandwidth consuming internet connection is done.
i suspect i did something wrong in my queue management.
or is it okay. I mean does winbox consumes so much of b/w.
Thankyou very much
Sanjeev
You can use torch to see how much bandwidth winbox is using.
Tools → Torch.
Checking mine now I am seeing 46kbps Tx 5kbps Rx.
If you find that winbox uses to much bandwidth you have the option to use the CLI through Telnet/SSH.
-Louis
Thanks Letni
I used torch and it showed Rx12.8 kbps and Tx382.3 Kbps
I have about 158 items in queue. I guess this factor is causing to consume so much of b/w.
Nope i am not that much comfortable using CLI
Thank you very much
Sanjeev
382 Kbps is too big, I don’t think it has anything to do with queue. Probably back end process is running,( window updates, virus updates..)
my winbox bandwidth,
rx-bits-per-second: 6.9kbps
tx-bits-per-second: 39.3kbps.
as Letni says : used torch to see actual winbox traffic
Hello friends
I did torch to find out bandwidth consumed by winbox
and i found 272.1 Kbps Tx consumed src address 255.255.255.255 Dst address 0.0.0.0 Dst port 20561
What’s going on ?? i can’t figure it out.
attached is the picture of snapshot the 4th line i didn’t understood.
Thankyou very much
Sanjeev
Same problem with me, but the Tx rate is 105 kbps and the Rx rate is 7 kbps
Same issue as per attached file
