Winbox: Feature Request – Proper handling of URI protocol (winbox://) arguments
:page_facing_up: Message Body (English – Recommended)
Hello MikroTik Support Team,
We would like to report a limitation and request an enhancement related to Winbox URI handling on Windows.
:magnifying_glass_tilted_left: Current Behavior
When Winbox is launched via a registered URI protocol, for example:
winbox://10.250.113.41
Windows correctly invokes:
winbox64.exe "winbox://10.250.113.41"
However, Winbox does not parse the URI and treats the entire string literally as the address, which results in:
  • Displaying winbox://10.250.113.41 in the Connect To field, or
  • An error such as:
    ERROR: invalid address - winbox://10.250.113.41
:check_mark: Expected / Desired Behavior
We kindly request that Winbox support basic URI parsing, such that:
  • winbox://10.250.113.41
    ➜ treated as 10.250.113.41
  • Optionally (if acceptable):
    • winbox://admin@10.250.113.41
      ➜ Address: 10.250.113.41
      ➜ Login: admin
We fully understand and do not request password support via URI, for security reasons.
:puzzle_piece: Why This Is Important
  • Many ISPs and NOC teams use web-based internal systems (CRM, CSMS, monitoring portals).
  • Launching Winbox directly from these systems would greatly improve workflow efficiency.
  • Currently, achieving this requires an external launcher or agent, which is undesirable and unnecessary if Winbox could handle simple URI parsing internally.
:desktop_computer: Comparison
Winbox already supports:
winbox64.exe 10.250.113.41
Adding minimal URI parsing logic (strip winbox:// prefix) would align URI usage with existing CLI behavior.
:locked_with_key: Security Consideration
  • No password handling is requested.
  • Only basic address and optional username parsing.
  • This change does not introduce additional security risks.
:folded_hands: Request
Please consider adding native support for the winbox:// URI scheme, with simple argument normalization, in a future Winbox release.
Thank you for your time and continued excellent work.
Best regards,
You should submit the feature request at Log into Atlassian - Support.
It does not work at all on MacOS. I suggested this in WinBox4 beta thread a while back, so supportive of your request here.
This would be a very nice feature indeed. Hoping that Mikrotik team implements this feature :slight_smile:
