Hey mikrotik
Is there any wine updates for mac os x 10.8?
Hey mikrotik
Have you tried this? It works for me: http://dl.dropbox.com/u/3669437/Winbox_1.4.dmg
Ok will do try
Normis it doesn’t work ![]()
works on all of my MacOS computers (tested on three). Do you have Xcode installed? Does any Wine program work?
even wine doesn’t work, xcode is required to run inbox?
Xcode is required for Wine
ahhh i see sorry normis I’m new to mac world since my new mac arrived today i’m having difficulties to run inbox hehe
Hi normis
I’m now struggling with this issue it says:
“Winbox” can’t be opened because it is from an unidentified developer.
as per instruction install Xcode but i did why doesn’t run? hayyyyysss
allow me to assist ← mac lover haha
goto settings> security> general, change “allow all applications”
fixed
other issue is montain lion update removed X11
if you still get errors
install this ALSO
http://xquartz.macosforge.org/landing/
it contains the X11 binaries.
the end
Oh and forget about being able to open multiple winbox at same time…
AND forget about being able to read text in “terminal” via winbox.
Normis,
Can you open multiple instances of this Winbox in your MAC?
Coffeecoo
It works, hehehe i believe that this coming dec 21 its not the end of the world ![]()
Thank you very much and merry christmas!
you can’t open multiple instances. better use Webfig then, it works in a browser, and has the same functionality
As long as I don’t bottle winbox into an app I can run as many instances as I want. I’m also running 10.8.
i noticed if you minimize the winbox window and then you maximum it doesnt back to normal window hehehe
works for me
