Winbox for macOS
The binary file http://mikrotikdownload.s3.amazonaws.com/WinBox-macOS.zip from page https://wiki.mikrotik.com/wiki/Manual:Winbox doesn’t work on latest macOS High Sierra, on previous macOS Sierra it works fine.
You can update it. Right click → Show package contents → Open “Wineskin” → Update wrapper.
Or you can just run Winbox.exe from Wine. To install Wine:
/usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
brew install wine
wine winbox.exe
Anyone else getting segfaults with Wine 2.0.3 and MacOS High Sierra 10.13.2 Beta?
