WinBox for MacOS ??
Well, one could only hope. While I’m getting along just fine using “CrossOver”, It would be very helpful if the Mikrotik crew would at least consider making a Native MacOS NetInstall. I can never seem to get it running on an emulator. :smiling_face_with_sunglasses::+1:
We do have plans for true multi platform Winbox. Finally. Let this be a teaser for 2022 :slight_smile: No ETA and no promises though.
I recently switched to macOS and installed WinBox using Brewery (https://brew.sh).
First you need to find Winbox using:
brew search winbox
It will find me casks with the name “nrlquaker-winbox”
Then I just need to install this casks:
brew install -cask nrlquaker-winbox -v
And that’s it :astonished:
Martin
Very exciting !
Hopefully with a more flexible and modern GUI toolkit
yeeeeeees, yes, yes, yes, yes, yes, yes, yes !
Why is this question in the wrong FORUM.
Normis please move to Beta Router or somewhere else.
Speculation doesnt count as a useful article :stuck_out_tongue_winking_eye:
I’m scared actually.
As a Windows user, I’m a bit scared too. I wish all the best to users of other systems, including for them to have nice native WinBox. But multi platform sounds as something common for all, so no need to develop the old WinBox anymore, and if it means complete rewrite, there’s so many things that can go wrong. What if we end up with some Electron-based monstrosity or something? I’m just preparing myself for the worst, so that I can be pleasantly surprised.
Sob living your life in constant fear is unhealthy. Like your fear that I may be right once! ;-PP
Normis has promised me that the new cross platform product will be even better.
The only requirement is that it will have to be run on a docker installed on a remote MT device and only accessible via a Zerotier connection to said docker.
I don’t know, there’s very common misconception that “new” and “better” are synonyms, so don’t hold it against me if I have some trust issues. :wink:
I wouldn’t be surprised if they used Electron, because then they could revamp webfig at the same time and use much of the same code for both. The other way would be to use some popular framework like Qt.
https://github.com/nrlquaker/winbox-mac
Yup, that what I use on my Mac for a long while, works great. Only learned recently that even “Check for Update” in mac-winbox even works, so I only installed it once, and upgraded it through at least 3 versions of winbox now. All the drag-drop stuff and file browsing works just fine too using wine.
As long time Mac and Mikrotik user, I share @Sob’s concerns here:
So this Apple fan boy prefer they improve the iOS app first, in particular iPad support – I still don’t trust it since it seems not always populate correctly/quickly so you can upload with stale/null data. And the iOS lacks tabs etc as the Android app, and generally not that great on iPad.
To me wine + winbox works just fine for Linux & Mac, so a winbox port to Qt/electron/Java/whatever seems like trading one non-native UI for another, with potential it take a long time to match all the subtle things winbox does… An improved iPad app be way more useful, we already use Lighting-to-Ethernet dongles with it, but the Mikrotik iOS app just isn’t that great and still buggy.
If you think about it, this could actually be a way of unifying the iPhone/iPad app with everything else. The iOS app does have that “basic mode” which is really handy for non technical users. Some people might just want to get that in a web browser or in a GUI tool like Winbox rather than having to use their phone or tablet to access it. A reimagined winbox could conceivably provide this “basic mode” with a device overview and simple tasks, and advanced mode for the detailed settings, like the app. Ideally you could create one code base that would be used for winbox, webfig, and the iOS app, and they just become different targets. Then theoretically you have feature parity across all three management options.
I really do use winbox daily on a Mac… But RN I have ZERO complaints about winbox, even on a Mac, so a replacement isn’t that appealing. Count me skeptical too, but it took 6 years to get automatic reconnect only added in v3.32 winbox.
:confused: Be curious to see what Mikrotik is doing, but focusing on desktop apps seems the wrong direction. Mobile/tablets are the majority of devices on the internet, while PC/laptops are decreasing in usage. I personally prefer to never use my Mac (or windows laptop) to manage a Mikrotik or anything, but the iPad interface is lacking. Long way from retiring MacBook, but prefer if I could get away with only a tablet. Trust me using any laptop on a roof is PITA. Qt or Electron ain’t going to help that problem.
Yeah the iOS/Android app’s “basic mode” part works pretty well (& some ways better than webfig/winbox QuickSet). But it’s the “Advanced” part where it’s tough to use the iOS app as a winbox-replacement – since you have to keep navigating the menus. Android app uses tabs so you switch between config screen easily, but iOS lacks this feature so it constant navigating down, then up, then down to do anything. The reviews on Apple App Store tell the story: https://apps.apple.com/us/app/mikrotik/id1323064830#see-all/reviews
Now I do think a richer iOS app be very difficult to do in a cross-platform manner…for example, Apple has macros “shortcuts”/app URLs that Mikrotik app could support (but doesn’t), now that be iOS-specific code support. Or, similar integration for events/logs/etc to Apple notification via the Mikrotik app. etc. etc. Or the multi-tasking views of iPad. etc. etc..
Basically prefer seeing an improved/update (e.g. more Apple-ish) iOS app, than “new & better” MacOS app. Basically swapping one cross-platform (wine) for another doesn’t have much appeal, at least to me.
Anyway, we’ll see what surprise Mikrotik have in store, maybe I’m wrong. Maybe they’ll have a revamped UI, beyond the 1990-style MVC windows app, but count me skeptical. They’ve let the iOS languish for a long time, so mildly annoying to see “hey we’re working on something ‘new and better’” when there’s stuff to “fix” today.
No offence but you are simply different portion of customers. Mikrotik devices are using SOHO and purely home users and then cell phone or tablet app for management may be ok, but.
BUT…
On another hand folks like I am have BIG company. With a lots of switches, routers, APs, hundreds of PCs and mobile terminals, with lots of people on home office.
There is no many models of Mikrotik hw which I don’t have.
Big company have such a wide spectrum of needs and Mikrotik is covering that for me very well.
I like mikrotik A LOT.
I got rid of it all proprietary hw during years. There is no HP, Cisco, Ruckus…nothing like that cannot through my my company doors.
And because almost all of my network HW is Mikrotik (99,99%), I am using Winbox A LOT.
And I mean a lot like a lot.
For me is this tool number one and it is running about 6-12 hours by day. In my office I am running winbox in wine (winehq repository) on Ubuntu (KDE Neon distro), on my workroom (in my house) I am running MacBook Pro 14" M1 with MacOS.
Same story here.
My work hours are mostly spit on half between this two places so I have my experiences with both platforms. And I don’t mention Windows because as I am always saying, windows is not a platform for IP/network/admin of any kind.
But back to linux/MacOs situation.
And it is no problem here and everything can be done with that setups. But is not native and it is noticeable.
There are just small details of this but when you run like that for thousands hours, you become getting it more and more.
So please, unless you not wearing my shoes for couple of years, do not say something like winbox for windows is ok, and it is enough, you can use web management, true sysadmin using ssh in command line anyway, blah blah…
Do not say PC ( I mean personal computers) are fading away and crap like that. Is maybe true and valid for you but there also admin which spending real hours in winbox an they need native version.
Maybe there is place for two different managing tools. PRO version and basic version. I dont know.
I would really appreciate it some more possibilities witch configuration of winbox.
Shortcuts. Different savable views for different devices (On wireless devices I am looking for different information and settings against ethernet routers and switches…).
Direct saveble icon-shortcuts for some concrete devices.
Different collors of WINBOX window for different devices based on “importance” ?? Stuff like that…
There is enormous potential for winbox and maybe it will be used. At least I am hope so.
We will never get a native version of WinBox for MacOS or Linux. It is very likely some cross-platform thingy. Rewritten in Java (LOL - I hope not) or Electron (LOL*2 - I hope not). Any cross-platform framework is kind of bloaty. They all have so much overhead and in the end they still do not feel like “native”. They are just a compromise to reduce development resources.
@Rushlife, no offense either :slight_smile: – just sharing my opinion. Certainly iOS is different topic, as would be still outstanding V7 bugs…so “better Mac support” nor “new winbox” are NOT very high on my list.
I just view “wine” as the cross-platform library, so they can keep improving the winbox and it still work on Mac/Linux via wine, vs. replace it with another cross-platform framework. But since it seems the ship already sailed here, we’ll just have to see what Mikrotik comes up with. winbox is working fine on my Mac so I can wait a while.
Still I’m betting both @mducharme and @sob are right. Specifically, winbox2 = webfig2 + JS/electron. We’ll see.
The open question here is will they still use winbox “secure” protocol in the new cross-platform, or will they move more standard protocol (TLS) to leverage all the rich/standard authentication, like x509 certs or 2FA. Maybe they’ll support REST API + QUIC, that be interesting since imagine winbox protocol is actually more efficient than HTTP.
But how Layer2/MAC discovery will work is another concern – that which works surprising well even under wine on Mac (and even with Mac ZeroTier client too).
This!!! Saved my bacon more than a few times.
Mikrotik have my full confidence. I think L2 mac discovery is so essential for this tool, It would be virtually useless without this ability…
We must hope :slight_smile:
