I wonder if someone ever notice that it is somehow difficult to use winbox on any crt lower resolution screen than 1024x768.
for example: Tools menu, i am unable to find netwatch because of its location place right on the bottom of the screen. the last submenu from tools is pingspeed, can’t see the rest of the tools’ sub menu…
.. especially for v3 ROS with full packages installed… the main menu seems to be more than v2.9… can see the submenu (from TOOLS or SYSTEMS …) even with big screen…
I don’t mean to be rude or anything but…come on…less then 1024x768? If you’re on that old of a monitor you need to learn the command line as you video card may overheat from the Winbox visuals =P
I too was bothered by this several times. [edit:] Especially the tools->netwatch, wich in CLI is hard to see, or to see all information provided by winbox.
Centering menus on screen instead from menu option down, would be good, and a scroll bar, when it’s needed, yes indeed. Centering menus on screen should be only a few lines of code.
Put it as “optional” not bug… it still works !
don’t mind me asking, which type of eeepc you are using? Thinking of getting one for myself, maybe the 4G series, but worried that it doesn’t take windows xp on the little space (4GB).
Cheers
