Is there a way to edit the winbox layout so you can view each device with the same layout. I looked around and it appears at one point there was an edit function for that, but I the copy of Winbox I have there is no edit. Thanks for any help.
GUI editing is available only for webfig, although this would be great for winbox.
Regards,
Sent from Tapatalk
You can not ‘edit’ the layout, but you can make changes and save the session.
I.E. open the windows you want to see, make changes to the columns, inline comments etc so it looks how you want it to look.
Then under file you can go ‘Save As’ and it will save as a .viw file, then in winbox you can choose a session from the dropdown before opening.
I have a few sessions based on the type of router im connecting to (PPPoE server, BGP router, Firewall router etc) and its important to untick ‘Autosave on close’ in winbox, so when you make changes as your looking around it doesnt overwrite your session file with that.
Thanks joegoldman, That is what I was looking for.
AlainCasault, I just want to edit the layout not the GUI. There are things I want to see on certain pages, not what is there by default. But I wanted to be able to do it in a mass edit sort of way.
