Winbox not accessing RB
I have a weird situation in which I cant access my routerboards using winbox 2.2.16 but I can with 2.0.8 Most of the RB are v3.25 and 4.15. I cleared cache but still the same. The Old version works just fine. Anythoughts?
Mike
Do you see the RouterBOARDs at neighbor discovery window?
Are you able to access the router by IP address?
In the new version I can access the RB when I use discovery and id the MAC. If I put in the address it just sets there thinking about it but never accesses it. The old version jumps right in with the IP address.
Do you have IP address from the same network on your laptop?
IP Address —No. But why should it make a difference as the old ver works but not the new?
I still do not understand, whether IP or MAC Winbox do no work for you.
MAC-address will not work over different networks.
IP address WInbox requires proper ip address - gateway configuration on both devices (there is nothing to do with the Winbox version).
