winbox setup from remote terminal
Can anyone help me set up winbox from a remote computer that is not on my system? I have copied the winbox login box, but I get a error message that sez can not connect to (my router address). Everything in winbox is the same as my computer that is on line via the wifi from this router. I have tried everything that the manual sez to do. Thanks pputter
The address you are trying to access, is it accessible from that PC? What happens if you try to do a tracert to it?
From what I can figure out, you are trying to access the internal address of your wireless network, but you are connected via internet and not your own network. If this is true, you’ll have to make use of a dyn-dns client such as changeip and use port forwarding to your router
