Hi Mikrotik Forum,
I have a running set of messages on my router, I cannot find the reason for. These are each 20-30 sec.
“Time” echo system, error, critical login failure for user admin from “IP address of the router itself” via winbox.
I would understand if the access was coming from outside of the LAN but from the router itself. I’m not sure I understand.
Would anyone have had the same issue ?
Laurent
Not for a RouterOS bug.
Not enough details have been provided to proceed further.
99% The Dude
Plausible, if itself is present in The Dude (and the dude have wrong password).
you were right.
As soon as I stopped the Dude, all messages stopped to pop up.
Now i need to find where I set login/pass on the dude to truly fix it ![]()
Many thanks
