Winbox to IPv6 to port 8295 - How do you do this ?
Mikrotik normally uses port 8291 for winbox
If you reconfigure the winbox service to function on port 8295 - then all you had to do to connect using winbox was to connect to a.b.c.d:8295
Now a problem I am encountering with winbox to an IPv6 numbered mikrotik.
If winbox is on a non-standard port such as 8295 , how do you winbox to it ?
Example what I am trying that is not working: winbox to IPv6 Mikrotik —> [2605:4e40:0:1fe::]:8295 (this does not work)
lil help here would be nice ….
North Idaho Tom Jones
Works for me. Not your address (I guess you don’t allow access from outside), but mine with non-standard port, exactly as you enter it, is ok.
All zeros for the host address is somewhat unusual, so may be a bug.
