*) fixed WinBox crash when viewing firewall rule with src/dst-address-type configured;
*) fixed checkbox group disabled state inheritance;
*) fixed dates and times in interface link up/down properties (RouterOS v6.47 required);
*) fixed system comment message display;
*) fixed vertical font alignment in optional fields;
*) fixed window size inheritance from the previous session;
*) keep advanced and simple mode table settings separately;
*) make WinBox upgrade work with wine 5.0 or newer;
*) properly show popup windows on top;
If you experience version related issues, then please report them to support@mikrotik.com.
Finally the window resizing has been fixed after numerous Winbox releases. Winbox now saves them and if you log in they are not getting bigger and bigger anymore.
New Winbox shows strange changelog in “system → packages” for stable tree ???
The error comes after “clear cache” only on the first device you connect after downloading descriptors. On other devices the changelog is OK. It stays strange only on the first connected device after performing a “clear cache” … No sorry…it is every 2nd time you connect
connect rb4011 … changelog OK … closing winbox … connect rb4011 … changelog NOT OK … closing winbox … connect rb4011 … changelog OK … and so on
Just tried it on several routers, but only see this behavior on a single device. A differentiating factor appears to be the number of records kept in the log. I see this on a device with 1000 record in the log buffer. And it is the actual number of rows that matter, as I have a CHR instance with the line limit set to 1000 but with only 120 records currently in the buffer, and I do not see this problem there.
Are there any plans to introduce something analogous to a taskbar in winbox, so that we can move seamlessly between open windows? Along with this, a miimize feature for open windows would also be useful.
I tried to set limit to 990 lines, there are 927 lines currently. Nothing changes, log goes to beginning after window restore. BTW, it’s RB1100AHx2, RouterOS 6.45.9.
Bug still exists on PC with HiRES display with 150% interface resize.
After winbox resized to needed size and disconnected, the winbox scale turns back to default.
