Or better when it would use multiple columns to fit everything without scrolling, when possible.
Yes, maybe that would be good too…
who had the “wonderful” idea of swap STOP and CLOSE buttons ??
i am accidentally closing many times because of that change
retunrning to 3.28 because of that
Super annoying, please reverse it back to the right way. Thanks ![]()
WHAT THE F*CK MIKROTIK?!?!?!?!
HOW CAN ANYONE BE SADISTIC IN SUCH A WAY?? START → CLOSE
I CLICKED “CLOSE” NOW 1000000000 TIMES INSTEAD OF STOP.
+1
remembers me at the good old days, and sophisticated win modal dialoges “YES means NO and NO means YES. Would you like to not fomat your disk now? YES | NO”
The best choice is to put the button every time in a random position, on that way, everytime we have to read what is written, instead of clicking like trained monkeys ...
Better Apple, simply has removed choices, someone has already decided what is better for you…
Request delay on start. I have happening when I double click the line in the list of devices in Winbox that I often happens that the second click also clicks a menu button on the left in main Winbox screen. The result is that for example the Make support.rif or any other button that is positioned under the mouse cursor.
thanks for the update! ive been waiting since early ros v2.x for the ability to re-organize winbox columns!! thank you so much MT, and please, PLEASE keep working on and improving winbox- it is the MOST critical Mikrotik software (right after rOS itself).
Almost all applications use tabs, I wonder why not here ![]()
Or you could put the Exit button at the bottom, and Windows just below New WinBox. You could also consider better optimization when using Zoom In, for example I use Zoom in to the maximum.
Also the scroll seems to remain a mystery in the application (in certain areas only), this makes me sad ![]()
It’s a plus anyway, but I know you can do a lot more! I greet you!
Please reverse your change that moved close below start in all the tools. PLEASE keep stop below start. It has wasted a significant amount of time already
Yes it is stupidity change moving down position of buttons !!! I am angry !
Is stupidity also click on button without know what the button does…
If something must be doed, simply must be used one unique [Start | Stop] button like [Simple Mode | Advanced Mode] on Wireless interface…
Hi.
I found an issue in winbox 3.29. when you upload a file into “File List” window into some directory, file name comes with full path. but when you change the file’s directory it will remain the same. unless you reopen the “File List” window.
in my test i changed un-befor-migration.tar file into skins and returning back to rook directory.
and also confirming http://forum.mikrotik.com/t/v7-1rc3-development-is-released/151711/1
When will built-in “Manual” section be directed to new documentation page? If open TOC in “Manual” window and click the link to new documentation page in it, Winbox just crashes…
WinBox v3.30 released:
http://forum.mikrotik.com/t/winbox-v3-30-released/151748/1
