*) added “Auto Reconnect” feature;
*) added fast selection of column checkboxes in “Columns” window by simply typing column name without spaces;
*) added support for “Tools->Telnet/SSH” extra parameters;
*) alert if there was error executing “Cancel” action;
*) fixed MAC connection in new window;
*) fixed WinBox when started by Windows “runas” tool with different user;
*) fixed crash on “Netwatch” entry “host” field;
*) fixed crash when table window was closed before its “Columns” window;
*) fixed delayed session window open with “Change Password Now” prompt;
*) fixed filter type “contains” for network fields;
*) fixed focus marker in checkboxes;
*) fixed graphs with values higher than 2^31;
*) fixed large text paste in “Terminal” window;
*) fixed some fields with empty IPv6 value;
*) fixed tables with max entry count feature;
*) fixed time value fields in “Scheduler” menu;
*) keep terminal lines intact when resizing “Terminal” window;
*) properly show all fields which depend on other field;
*) release “Safe Mode” with info message, when other user took it;
*) restore “Managed” table when toggling “Advanced” mode;
*) sort “Columns” window alphabetically;
*) use router’s time in graphs;
*) use router’s time in last link up/down fields;
If you experience version related issues, then please report them to support@mikrotik.com.
the date in files-cloud backup it is not shown with correct timezone.
double click to connect in winbox tab neighbours and romon neighbours
an option to export or copy to notepad selected rules in winbox windows. eg when in tab firewall-filter right click to copy/export to rsc selected rules.
Because it would require a full re-write, for something that works perfectly fine in WINE, also offering WebFig which is OS independent GUI.
If they ever got to a point where they have more developers than work required on RouterOS then maybe they’d commit some resources to a full winbox rewrite but right now it’d be a waste of time and money.
Routing-Table Box for IPv6 routes is still missing in Winbox GUI, so route has to be completed or added via console when using different routing table.
I don’t recall MikroTik promised anything or any time frame and for most users the Windows version is perfectly usable as it is even on Linux therefore it doesn’t seem to be a priority so how can it be overdue?
That is nice. Even better would be when it could do this without destroying the window, going back to the new connection window, and then setting up a new window for the connection.
E.g. by handling everything using messages in the button bar.
Reason: when using a “desktop pager” under Linux (does that even exist under Windows? I cannot live without it…) the newly created window appears on the desktop that currently has the focus, instead of the desktop where it originally existed.
I used to think that, but it be better if they improved the iOS app and allowed it to run on Mac… I’ll say it used to be more dicey with wine, but yeah since I’ve notice MT videos with Macs…wine with winbox has seem to work flawless for past year+.
Even the Tools > Check for Update works just fine on Mac (only found that around v3.2x something), so already on v3.32 - connected to a remote v7.2rc1 device via ZeroTier. I’ve been shocked that the “Check for Update” works now through few version upgrades with winbox on Mac – great work.
