WinBox v3.32 released!
See https://wiki.mikrotik.com/wiki/Manual:Console#List_of_keys
Ctrl-X is SafeMode. HotMode or “Hotlock” was/is is Ctrl-V. I thought it was removed from V7, but @Chupaka right it’s winbox where it doesn’t work using Ctrl-V (F7 now). But Hotlock does work when you SSH in using Ctrl-V, so it’s just the Winbox terminal where the Ctrl-V isn’t taken.
Edited: another thread had this comment from Mikrotik:
HotLock mode hotkey has been changed too. Now it is F7 (Ctrl-V removed). Winbox Terminal still doesn’t support Ctrl-V, though. You have to press Shift+Ins to paste. But at least now you won’t accidentally activate HotLock mode while trying to paste.
Are those types of changes documented somewhere?
https://help.mikrotik.com/docs/display/ > … ListofKeys
Yeah, sorry, I meant Ctrl+V for Hotlock. The hotkey was changed for v7 only, so it doesn’t work in v6 with recent versions of WinBox.
I’m still seeing some issues with saving the column selections. In some cases a newly added column will not “stick” in the saved session.
I can reproduce this e.g. for the “Used Hold Time” column in Routing->BGP->Peers. It is gone every time I open this window and its width is set to the default when I re-add it.
*) sort “Columns” window alphabetically;
Well, sometimes that is an improvement, sometimes it isn’t. In long lists, the original unsorted listing tended to group them by function and this is gone now that they are alphabetically listed.
Also, the same name sometimes appears twice (a longstanding bug) but in the old situation one could differentiate e.g. the setting value and the active value by the position in the list. That no longer works.
It would be nice when the sorting can somehow be made optional (either by global setting or a checkmark in the dialog itself).
Graphings with high values now displays correctly, but when you click on a specific column the current label value is wrong
In this example the label at the right should be around 5000Mb instead of 1750Mb
WinBox v3.33 released:
http://forum.mikrotik.com/t/winbox-v3-33-and-v3-34-released/155731/1
