WinBox v3.41 released!
What’s new in v3.41:
*) added support for new internal WinBox protocol fields;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
Thanks, but - where to get winbox for mac OS???
@VadiKO,
WineSkin/Wine?
@Kanzler,
I’m not against WineSkin for Windows, please use the normal WinBox v3.41 released for Mac OS! So will it be fair?
There never has been winbox for MacOS.
On Linux boxes you can run it via Wine, I suppose MacOS has something similar.
What are these fields? In which windows are these used, or are they not yet used by RouterOS?
Is this a fix for the “some windows won’t auto-update” that was introduced long ago with V7 (and seems to be getting worse)?
Yes, Winbox runs fine with wine on Mac OS, both intel based and apple silicon.
I guess they added new “protocol fields” for the new WinBox app. Now added to legacy WinBox as well so it can still be used.
This is basically WInBox release for future use. At some point, 3.41 will become the minimal supported WinBox version. For end user, this release does not change anything.
What do u mean by future use?
I am pretty excited on the upcoming changes.
I can confirm v3.41 is working even with older ROS 7.13.5.
When I asked about the problem of BGP sessions window not being auto-refreshed with RouterOS v7 I got the reply that this would require a new Winbox version.
Recently I noticed that there are also refresh issues in the IP routes window, e.g. “immediate gateway” is not updated until F5 is pressed several times and/or the specifc route line is doubleclicked first.
I seems that RouterOS development is continuing and Winbox stays behind.
Is there any plan and schedule for that “new Winbox version”? It seems 3.41 is not it.
Tell me more about how you do it? maybe you have a video?
Thanks )
There are already so many videos about that… did you even attempt to search?
Even Normis made one.
Thanks, I’m findin this https://www.youtube.com/watch?v=TCPhYh9Wajw
Works even with 6.44.6
Fortunately, yes.
I still operate a mix of v6/v7 systems, the oldest being 6.47.9, and I would hate to have a situation where I need to keep different versions of winbox to communicate with all of them…
Fortunately Winbox is portable so we do not have the same problem as it is with Dude…
What’s the problem with Dude running with Wine?
There is no 64-bit version of Dude.
