winbox it works if within through interface wifi but it does not work if within through interface ethernet
why?
regards
davide
Why not? It works perfectly for me through ethernet connection.
Whats the error you get?
try with secure mode off
make sure you have only on network card on in your pc
HI
Check if the firewall is activate for the ethrnet connection
If you are trying to connect via MAC, then make sure IP neighbour discovery is on for that interface
